    Issue on copying from Notepad++
    3 Posts 2 Posters 3.3k Views
    • Tibor WeigandT
      Tibor Weigand
      Hi!
      On my workplace I’m opening prepared Juniper JunOS configurations in Notepad++ (these are .wri files), visually check them and paste on the appropriate router. After syntax check by JunOS, I’m receiving errors, which do not occur if I open the .wri file in any other editor (Wordpad, MS Write…) instead of Notepad++.
      Does someone has similar issues, maybe in some other situations when pasting from Notepad++?
      • Timothy BilesT
        Timothy Biles
        Save an example output from Notepad++ and do the same with Notepad or other editor that isn’t mangling your config. diff the files and see what has been changed. I’m no notepad++ expert, but maybe an autocorrect or autoformat feature is turned on that is tweaking something that you don’t intend?
        • Tibor WeigandT
          Tibor Weigand
          Hi Timothy,
          it was my first idea too, I tried to check the copied text from e.g. Write and Notepad++ in WinMerge (winmerge.org), but these were without differences! :-P :-D
          I will try to ask the same question on some Juniper community and see if someone else had the same issue…
