    Dark Mode style for UDL
    7 Posts 3 Posters 870 Views 2 Watching
    • dfs-D Offline
      dfs-
      Is it possible for a user-defined language to include additional information for dark mode?
      Currently my UDL describes colors that are good for light mode (= white canvas/background)…
      …but are hard to read in dark mode (= greyish canvas/background)…
      Finding a middle ground seems quite hard, so I wondered if it is possible to modify the style for the dark mode the same way it works for the included languages?
      Notepad++ v8.9.2   (64-bit)
      Build time: Feb 13 2026 - 02:47:53
      Scintilla/Lexilla included: 5.5.8/5.4.6
      Boost Regex included: 1_90
      pugixml included: 1.15
      Command Line: C:\Development\GIT\SWLLIS\dbsystem\dbcreate\Befund\befundauftrag.pro
      Admin mode: OFF
      Local Conf mode: OFF
      Cloud Config: OFF
      Periodic Backup: OFF
      Placeholders: OFF
      Multi-instance Mode: monoInst
      asNotepad: OFF
      Dark Mode: ON
      Display Info:
          visible monitors count: 3
              0000: Description - Intel(R) Iris(R) Xe Graphics
              0000: DriverVersion - 32.0.101.7077
              0001: Description - Microsoft Remote Display Adapter
              0001: DriverVersion - 10.0.19041.5794
              0002: Description - Microsoft Remote Display Adapter
              0002: DriverVersion - 10.0.19041.5794
      OS Name: Windows 10 Pro (64-bit)
      OS Version: 22H2
      OS Build: 19045.6456
      Current ANSI codepage: 1252
      Plugins:
          ComparePlus (2.2)
          ElasticTabstops (1.5)
          JSMinNPP (1.2312)
          mimeTools (3.1)
          NppConverter (4.7)
          PlantUMLViewer (1.9.0.13)
          PythonScript (2)
          XMLTools (3.1.1.13)
        PeterJones @dfs-
        @dfs said in Dark Mode style for UDL:
        You define two separate UDL (two separate files), one with your light colors, one with your dark colors. Then, as is done in markdown._preinstalled_DM.udl.xml (which comes preinstalled when you get N++), you set darkModeTheme="yes":
        <UserLang name="Markdown (preinstalled dark mode)" ext="md markdown" darkModeTheme="yes" udlVersion="2.1">
        (yours would, of course, have the name and extensions appropriate for your UDL)
        When you have both those UDL in Notepad++, then when it’s in Dark Mode, it will use the settings from the UDL with darkModeTheme="yes", and when in Light Mode, it will use the settings from the UDL without that attribute (or with that attribute set to "no", IIRC).
        Lycan ThropeL 2 Replies Last reply Reply Quote 2
        • dfs-D Offline
          dfs-
          Thank you @PeterJones, this is a perfect solution.
          • Lycan ThropeL Offline
            Lycan Thrope @PeterJones
            @PeterJones ,
            Hmm, I wasn’t aware of that. Now I have to go and experiment. I created the two files, but never thought about that setting as I thought the darkmode setting was in the config.xml and you had to change the environment manually which is why we needed to create two separate files.
              @PeterJones ,
              To verify, I’m not sure if that “no” switch is effective or not, but on the 8.9.2 version plain vanilla, I downloaded the dBASE language files and changed just the Dark mode file with the darkModeThene="yes" switch, and just switching between dark mode and light mode, and opening the same code file in each allowed for the change to take place, magically.
              Thanks, now I can get rid of my contextMenu.xml hack for switching between the Dark and Light version, and when I finish the other dBASE dialects, they’ll be the only choices I need to put in the contextMenu.xml to switch between them. Because of the same named file extensions and similarity in much of the language syntax in files between them, it may require manually choosing the right version on opening them and the right click will be dedicated to that purpose. Thanks for that info.
              dfs-D 1 Reply Last reply Reply Quote 1
              • dfs-D Offline
                dfs- @Lycan Thrope
                Only downside is doing this for all custom languages (i.e. 10 in my case) effectively duplicates them and makes the Language menu quite cluttered and hard to use.
                It would be nice, if UDLs would be sorted within the preinstalled languages, but as far as I remember this wouldn’t be trivial to implement…
                  Lycan Thrope @dfs-
                  @dfs ,
                  We could go a step further and lament that it would be nice if the entire graphical environment of NP++ could be contained in one dialog setting, and then when we switched between Light or Dark, the environment would change all the UI references:
                  Settings->Preferences...->Dark Mode,
                  Settings->Style Configurator...->Style:, and the
                  Settings->Style Configurator...->Select theme:
                  …could be coordinated to make just switching between Dark Mode and Light Mode change them all, accordingly. As it is, I’m glad to have just found out that the Dark and Light language files can automatically change by setting that one switch in the dark mode file @PeterJones mentioned, and that automatically chooses the correct code coloring file for the environment (Dark/Light) chosen.
