    Need help with finding and replacing
    2 Posts 2 Posters 1.0k Views 2 Watching
    • Chec PufosC Offline
      Chec Pufos
      Hello, i have 30 notepad files in which i want to change a number at certain lines.
      This is the lines that are found in each document:
      Size {
              #  [range: 1 ~ 256000, default: 1000]
              I:max=1000
              #  [range: 1 ~ 256000, default: 500]
              I:min=500
      I want to change the number after i:max and i:min in each document, but be aware that there are other places where these 2 appear and i need to change the numbers only in these specific lines. How can i do that? Also, the number after ''default: ‘’ it is different in each document in both lines.
      moderator added code markdown around text; please don’t forget to use the </> button to mark example text as “code” so that characters don’t get changed by the forum
        PeterJones @Chec Pufos
        @Chec-Pufos ,
        Your specs are more vague than you think they are.
        Assuming you want to replace any positive integer immediately after that specific I:max= with 987 and any positive integer immediately after that specific I:min= with 654, then it could be done with something like:
        FIND = (?-is)(Size\s+{\s*.*\R\s*I:max=)\d+(\s*.*\R\s*I:min=)\d+
        REPLACE = ${1}987${2}654
        SEARCH MODE = Regular Expression
        REPLACE IN FILES
        hopefully, you can figure out what to change in order to replace with values other than 987 or 654
        highly recommended: always back up your data before trying a regex that someone hands you; always try a new regex on a single file and make sure it behaves as you expect before trying on the full 30 files.
        Useful References
        • Please Read Before Posting
        • Formatting Forum Posts
