    Perl keywords "class" and "method" not recognised by Function List
    13 Posts 3 Posters 2.0k Views 2 Watching
    • J Offline
      JohnL22
      The language highlight for perl recognises new keywords - class, field, ADJUST, method - BUT the Function List does not recognise class or method entries
        PeterJones @JohnL22
        @JohnL22 said in Perl keywords "class" and "method" not recognised by Function List:
        The syntax highlight keyword lists are separate from the FunctionList parser, so having added one doesn’t guarantee having added the other.
        And during the last update of the FunctionList parser, the test file that was being used didn’t already include that syntax, so I forgot to add in the class to match package and method to match sub. (I haven’t started using the new perl class/method syntax yet)
        Does this screenshot do what you want? (I added the class NewClassSyntax section to the Perl FunctionList test file for this screenshot)
        using a file ending with…
        ################ From here on was added by pryrt/PeterJones to test Notepad++'s FunctionList, and is not part of pltags source code
        sub MyClass::new        { return bless {}, 'MyClass' }
        sub MyClass::do_thing   { return 42 }
        sub MyClass::debug      { print "ok\n" }
        sub Other::run          { return 'running' }
        sub Other::stop         { return 'stopped' }
        package NameSpace::Block {
            sub inBlock { return 1 }
            sub inBlockProto($) { return $_[0] }
            sub inBlockAttrib :prototype($) { return $_[0] }
        package NameSpace::Semicolon;
        sub afterSemi { return 0 }
        class NewClassSyntax {
            method inBlock { return 1 }
            method inBlockProto($) { return $_[0] }
            method inBlockAttrib :prototype($) { return $_[0] }
        If so, then you can replace c:\program files\Notepad++\functionList\perl.xml with
        |   link:
        <NotepadPlus>
        	<functionList>
        		<!-- ======================================================== [ PERL ] -->
        		<!-- Perl - functions and packages, including fully-qualtified subroutine names -->
        			... replacement perl parser ...: https://community.notepad-plus-plus.org/topic/19842
        			... make sure to rename the id\s*=\s*"perl_function" near the beginning with "perl_syntax" to match
        			... 2025-11-26: Improve the regex to not include as much pointless backtracking
        			<parser
        				displayName="Perl"
        				id="perl_syntax"
        				commentExpr="(?x)                                               # free-spacing (see `RegEx - Pattern Modifiers`)
        							(?m-s:\x23.*$)                                      # Single Line Comment
        						|	(?s:__(?:END|DATA)__.*\Z)                           # Discard up till end-of-text
        				<classRange
        					mainExpr    ="(?x)                                          # free-spacing (see `RegEx - Pattern Modifiers`)
        							(?m)                                                # ^ and $ match at line-breaks
        							(?'PACKAGE_HEADER'
        								^                                               # NO leading white-space at start-of-line
        								(?-i:(?:package|class)\b)
        							(?s:.*?)                                            # whatever,
        							(?=                                                 # ...up till
        								\s*                                             # ...optional leading white-space of
        									(?&amp;PACKAGE_HEADER)                      # ...next header
        								|	\Z                                          # ...or end-of-text
        					<className>
        						<nameExpr expr="(?x)                                    # free-spacing (see `RegEx - Pattern Modifiers`)
        								\s
        								\K                                              # discard text matched so far
        					</className>
        					<function
        						mainExpr="(?x)                                          # free-spacing (see `RegEx - Pattern Modifiers`)
        								(?m)
        								^\h*
        								(?:sub|method)
        								\s+
        								(?:\w++\:\:)*                                   # optional prefix::package::names::
        								\w+
        								\s*+(?:\([^()]*+\)\s*+)?+                       # prototype or signature
        								(?:\:[^{]+)?+                                   # attributes
        								\{                                              # start of function body
        						<functionName>
        							<funcNameExpr expr="(?x)                            # free-spacing (see `RegEx - Pattern Modifiers`)
        									((?:sub|method)\s+)?
        									\w+                                         # move the \K to just before this line if you don't want prefix::package shown in the functionList Panel
        						</functionName>
        					</function>
        				</classRange>
        				<function
        							(?m)
        							^\h*
        							(?:sub|method)
        							\s+
        							\w+                                                 # add \K before the \w+ if you don't want prefix::package:: shown in the functionList Panel
        					<functionName>
        								(?:(?:sub|method)\s+)?
        								\w+
        					</functionName>
        					<className>
        						<nameExpr expr="(?:sub|method)\s+\K\w+(::\w+)*(?=::\w)"/>
        					</className>
        				</function>
        			</parser>
        	</functionList>
        </NotepadPlus>
        and try it out for a while. If it does what you expect, let me know, and I can create an official Issue and submit the updated FunctionList definition with class and method added.
        And if you have examples of class or method definitions that include syntax that this updated functionList parser doesn’t handle right, give me a brief snippet of code which shows the ones that aren’t done right…
        update: for example, do you think ADJUST blocks should show up in as functions/methods in the FunctionList panel or not? Since it’s just code that’s run during object construction, so it’s more like a BEGIN/END block, which don’t show up as functions in the FunctionList, so I would lean toward not including them, but I could be persuaded otherwise.
        • guy038G Online
          Hello @peterjones, @johnL22 and All,
          Peter, adding the part :
          At the end of the uniTest.txt file
          And updating the perl.xml file, within the Function List folder, does display the same function list view than your screenshot !
          Sorry, I’ve just forgot to test your new perl.xml file, so far, in order to simplify some regexes, if possible. I’ll have to find some time to get started on it !!
          • J Offline
            JohnL22
            PeterJones et al
            Thank you,
            That looks to be what I would expect the Function List to contain.
            I only use the most simple syntax of “class” and “method” currently.
            I agree ADJUST is very like BEGIN & END (which I have NOT yet used), so I am undecided about including them in the Function List.
            I will use your updated code, test it out, and confirm it does what I need soon.
            Regards
              @PeterJones said in Perl keywords "class" and "method" not recognised by Function List:
              Please note: the bad highlighting on the $) on lines 325 and 326 compared to 316-317 is caused by the underlying lexer from the Lexilla library project. I have already created an issue there to get that resolved; it cannot be fixed in Notepad++ until it’s fixed in Lexilla.
              (This is separate from the Function List behavior, but since I thought you might notice something like that if you used prototypes, I decided to point it out.)
              • guy038G Online
                Hello, @peterjones and All,
                I finally succeeded to get a new perl.xml file parser !
                In short :
                • I do NOT use any atomic construction !
                • In mainExpr of the class range, I do NOT use a named group but, simply, use the part ^ (?: package | class ) \b, twice !
                • I changed your prototype / signature syntax (?:\([^()]*+\)\s*+)?+ to (?: \( [\x20-\x27\x2A-\x7E]* \) \s* )?
                • I changed your attributes syntax (?:\:[^{]+)?+ to (?: : [\x20-\x7A\x7C-\x7E]+ \s* )?
                So, for these two syntaxes, I just supposed that standard ASCII characters are used, from \x20 to \x7E, except for \x28 and \x29 in one part and \x7B in second part ! May be, the \t should be part of each class character, either !
                • I changed the regex class name (?x)\s\K[^;{]+ to (?x)\s+\K.+?(?=[;{])
                BTW, my parser presently contains 13 strings \s. May be, the \h or even [\t\x20] should be more appropriate, in some parts ?
                Also, how many optional parts (?: \w+ :: )* may exist, before the mandatory \w+ of the function name ?
                Anyway, this is a first draft. As I’m definitively not a Perl Expert, I probably missed a lot !
                So, here is the first version of my Perl.xml parser :
                |   link:
                <NotepadPlus>
                	<functionList>
                			<parser
                				displayName="Perl"  id="perl_syntax"
                				commentExpr="(?x)                                               # 'Free-spacing' mode (see `RegEx - Pattern Modifiers`)
                							(?m-s:                                              # 'Multi-lines' mode ( ^ and $ match at line-breaks ) / 'Dot' char does NOT match line-breaks
                								\x23 .*                                         #   Single Line Comment ( #................ )
                							|                                                   # OR
                							(?s:                                                # 'Single line' mode (letter s optional as mode set by DEFAULT)
                								__ (?: END | DATA ) __                          #   String '__END__' or '__DATA__'
                								.*                                              #   ANY character(s), including line-breaks, till...
                								\Z                                              #   Last line-break, included
                				<classRange
                					mainExpr="(?x)                                              # 'Free-spacing' mode (see `RegEx - Pattern Modifiers`)
                							(?m-i)                                              # 'Multi-lines' mode (^ and $ match at line-breaks) / 'Sensitive case' mode
                							^                                                   # NO leading white-space at start of line
                							(?: package | class ) \b                            # Header : word 'package' or 'clas', in LOWER case
                								.+?                                             #   ANY character(s), including line-breaks, till...
                                            )                                                   # Section below, excluded
                							(?=                                                 # Start of look-ahead
                								\s*                                             #   Optional leading white-space of
                								(?: package | class ) \b                        #   Next header : word 'package' or 'clas', in LOWER case
                							|                                                   # OR
                								\Z                                              #   last line-break
                							)                                                   # End of look-ahead
                					<className>
                						<nameExpr expr="(?x)                                    # 'Free-spacing' mode (see `RegEx - Pattern Modifiers`)
                										\s+                                     # Leading white-space(s)
                										\K                                      # Discard text matched so far
                										.+?                                     # ANY character(s) till...
                										(?= [;{] )                              # First semi-colon or left brace, excluded
                					</className>
                					<function
                								(?m-i)                                          # 'Mutli-lines' mode (^ and $ match at line-breaks) / 'Sensitive case' mode
                								^ \h*                                           # Optional leading spaces or tabulations
                								(?: sub | method ) \b                           # Word 'sub' or 'method', in LOWER case
                								\s+                                             # White-space character(s)
                								(?: \w+ :: )*                                   # Optional list of words EACH followed with ::
                								\w+                                             # Word character(s)
                								\s*                                             # Optional white-space character(s)
                								(?: \( [\x20-\x27\x2A-\x7E]* \) \s* )?          # Optional Prototype or Signature section
                								(?: : [\x20-\x7A\x7C-\x7E]+ \s* )?              # Optional Attributes section
                								\{                                              # Start of function body
                						<functionName>
                							<funcNameExpr expr="(?x)                            # 'Free-spacing' mode (see `RegEx - Pattern Modifiers`)
                												(?: sub | method )              # Word 'sub' or 'method', in LOWER case
                												\K                              # Discard text matched, so far (move this line right before \w+ if 'prefix::' part NOT desired)
                												(?: \w+ :: )*                   # Optional prefix:: part ( package:: / names:: )
                						</functionName>
                					</function>
                				</classRange>
                				<function
                							(?: \w+:: )*                                        # Optional list of words, EACH followed with ::
                					<functionName>
                										\K                                      # Discard text matched, so far ( move this line right before \w+ if part 'prefix::' NOT desired
                					</functionName>
                					<className>
                										( :: \w+ )*                             # Optional list of words, EACH preceded with ::
                										(?= :: \w )                             # Till a last string ':: + word char' excluded
                					</className>
                				</function>
                			</parser>
                	</functionList>
                </NotepadPlus>
                May be, it would be interesting to compare my version to yours, in terms of speed. To my mind, it’s seems similar !?
                  PeterJones @guy038
                  @guy038 said in Perl keywords "class" and "method" not recognised by Function List:
                  Perl allows Unicode alphanumeric/“word character” in any such identifier or token (just cannot start with a numeric), so restricting to ASCII is not going to work
                  • J Offline
                    JohnL22
                    I have used the changed perl.xml for more than 2 weeks.
                    It handles all formats of “class” definitions - test file attached…
                    The only time it sometimes stumbles is when there is no class-ending statement after the “STATEMENT form of class” before the end-of-file. I can not yet reliably reproduce the situation
                    I will not comment on recognising identifiers in perl syntax.
                    PeterJonesP 3 Replies Last reply Reply Quote 0
                      PeterJones @JohnL22
                      @JohnL22 ,
                      The image you showed has no stumble. Zooming in:
                      The green arrow points to the fact that most of the classes are set to show their contents, so have the ﹀ down arrow next to them. The red arrow highlights the fact that the final class is set to be collapsed (hiding the functions/methods in that class), so has the > right arrow. If you want to see the methods in VERSION_ATTR_STMT 3.5, you need to click the > to make it a ﹀
                      becomes
                      by toggling that arrow.
                        PeterJones @JohnL22
                        The other possibility is that you didn’t have final newline/whitespace after the last line of code. That’s a long-standing issue buried deep in the FunctionList implementation that no one has been able to fix:
                        No newline:
                        vs with newline:
                        If you cannot force yourself to remember to always have the final newline in your file, you can use the EditorConfig plugin and set insert_final_newline = true for [*.p{l,m}] or for [*]
                        J 1 Reply Last reply Reply Quote 0
                          PeterJones @JohnL22
                          @JohnL22 ,
                          … but since it’s essentially working for you, I have taken that as confirmation that the new perl.xml is an improvement, so it’s in a Pull Request now… hopefully, it will get merged for the v8.9.1 release candidate coming next week.
                          update: PR has been merged,so it will be in 8.9.1
                          • J Offline
                            JohnL22 @PeterJones
                            @PeterJones I am happy :)
                            • guy038G Online
                              Hello, @peterjones,
                              First, read this post to @coises, where I discuss the Unicode concept of identifiers, particularly in Perl !
                              Thus, as explained at the end of that post, I created a second version of my perl.xml file parser which should work correctly without significant delay !
                              In short :
                              • I do NOT use any atomic structure !
                              • I changed your prototype / signature syntax (?:\([^()]*+\)\s*+)?+ to (?: \( [\x20-\x7E\w]* \) \s* )?
                              • I changed your attributes syntax (?:\:[^{]+)?+ to (?: : [\x20-\x7A\x7C-\x7E\w]+ \s* )?
                              In the two syntaxes above, I simply added \w within each character class
                              Note that, from this article https://www.effectiveperlprogramming.com/2015/04/use-v5-20-subroutine-signatures/, the following syntax seems possible :
                              sub animals ( $cat, $auto_id = get_id() ) {
                                  say "$auto_id: The cat is $cat";
                              Thus, for prototype / signature syntax, I’ve allowed parentheses within the outer parentheses. If this example seems not pertinent, use the alternate syntax :
                              (?: \( [\x20-\x27\x2A\x7E\w]* \) \s* )?
                              • Finally, I changed the regex class name (?x)\s\K[^;{]+ to (?x) \s+ \K .+? (?= \x20* [;{] )
                              BTW, my parser presently contains 13 strings \s. May be, the \h or even the [\t\x20] syntax should be more appropriate, in some parts ?
                              |   link:
                              <NotepadPlus>
                              	<functionList>
                              			<parser
                              							|                                                   # OR
                              				<classRange
                              							|                                                   # OR
                              					<className>
                              										(?= \x20* [;{] )                        # First semi-colon or left brace, excluded
                              					</className>
                              					<function
                              								(?: \( [\x20-\x7E\w]* \) \s* )?                 # Optional Prototype or Signature section
                              								(?: : [\x20-\x7A\x7C-\x7E\w]+ \s* )?            # Optional Attributes section
                              						<functionName>
                              						</functionName>
                              					</function>
                              				</classRange>
                              				<function
                              							(?: \w+ :: )*                                       # Optional list of words, EACH followed with ::
                              					<functionName>
                              					</functionName>
                              					<className>
                              					</className>
                              				</function>
                              			</parser>
                              	</functionList>
                              </NotepadPlus>
                              In the https://github.com/notepad-plus-plus/notepad-plus-plus/blob/a91b22bd8337465e04c1afa30cb71f7909340293/PowerEditor/Test/FunctionList/perl/unitTest file, I added text at various locations :
                              • Before the line ############### Start ###############
                              ################ Added by guy038 to test Notepad++'s FunctionList
                              sub animals ( $cat, $autoid = get_id() ) {
                              	say "$auto_id: the cat is $cat";
                              sub _function_été {
                                  return 1
                              • Before the line package NameSpace::Block {
                              sub grâce::Hôte          { return 'running' }
                              sub grâce::Son_ø         { return 'stopped' }
                              • At the very end of file :
                              class Chaîne{
                                  method Dûment($) { return $_[0] }
                                  method ƒ_Hameçon :prototype($) { return $_[0] }
                              In terms of speed, the Function List panel seems quickly displayed. I also did a test copying UniTest.txt twice, and then adding, by regex, _1, _2 and _3 at end of the different names, the Function List panel still appeared without delay !
