    RegEx assistance for adding a space before an Upper case letter
    2 Posts 2 Posters 161 Views
    • Brenda Gross 0B
      Brenda Gross 0
      I have hundreds of table column names that contain no embedded spaces. Some of the column names use an _ to separate words, some use camel case, some use a mixture. Replacing the _ with a space is easy. But how to add a space prior to any upper case character that is not the first character and is not already preceded by a space? Each column name will be on a separate line. Thanks for any help
      Example:
      Average_Balance
      SystemRate_Change
      DateClosed
      Desired Results:
      Average Balance
      System Rate Change
      Date Closed
        Hello, @brenda-gross-0 and All,
        Very easy with regexes !
        • Un-tick all box options
        • FIND (?-i)(?<=\l)(?=\u)|_
        • REPLACE \x20
        • Tick the Wrap around option
        • Click, once only, on the Replace All button
        Voila !
        Notes :
        • The leading part (?-i) is an in-line modifier which force to take care about the case of letters, meaning non-insensitive search !
        • Then, due to the alternation symbol |, two individual regexes are performed, simultaneously :
          • (?<=\l)(?=\u) which searches for an empty string between a lower-case letter and an upper-case letter
          • _ which simply searches for the underline character
        • In both cases, the replacement changes the regex search with an normal space character \x20. I could have chosen to type a single space char, instead !
        • The regex search may also be expressed as a non-capturing group : (?-i:(?<=\l)(?=\u)|_), with the leading non-insensitive option
