    Issue with XML Tools Pretty Print
    1 Posts 1 Posters 163 Views
    • Chuck Rheault 0C
      Chuck Rheault 0
      XML
      In recent uses of Notepad++, I found the XML Tools Pretty Print was adding extra lines to the file and making it badly formed. The Workaround that I found wors was to first use the Pretty Print - Indent Attributes and then, if I used Pretty Print, it operated correctly.
      When it fails, it was usually a file with a large block of text with no carriage returns or indents.
      I just installed v8.8.7 64 bit and it seems to be fixed.
