Add iNVERT cASE in the Right Click Menu
In the Right Click menu, after “UPPERCASE” and “lowercase” items, add a new one, “iNVERT cASE”, that would, as the 2 existing ones, point to the “Edit > Convert Case to” according item.
Versailles, Fri 22 Aug 2025 17:37:50 +0200 -
You can customize the right-click context menu for your own use; consult the user manual (found via the
?menu in Notepad++) for details on how.
