    NPP v8.8.3 64 bit, turning on dark mode in settings closes/crashes npp window
    5 Posts 2 Posters 274 Views
    • Paul LeoP
      Paul Leo
      Hello,
      Just downloaded and installed npp v8.8.3.
      Have many plugins installed (see below).
      Have multi instance enabled
      Have one instance of npp with two tabls open.
      Start another instance of npp
      In that instance of npp, with no files open in that instance :
      I go to Settings/Preferences/Dark Mode, then choose dark mode button.
      As soon as I do that, that instance of npp closes.
      Here’s my debug info:
      Notepad++ v8.8.3 (64-bit)
      Build time : Jul 9 2025 - 01:39:59
      Scintilla/Lexilla included : 5.5.7/5.4.5
      Boost Regex included : 1_85
      Command Line :
      Periodic Backup : OFF
      Placeholders : OFF
      Scintilla Rendering Mode : SC_TECHNOLOGY_DEFAULT (0)
      Multi-instance Mode : multiInst
      Dark Mode : OFF
      Display Info :
      primary monitor: 2560x1440, scaling 125%
      visible monitors count: 2
      0000: Description - NVIDIA Quadro RTX 3000
      0000: DriverVersion - 32.0.15.7322
      0001: Description - Intel® UHD Graphics
      0001: DriverVersion - 31.0.101.2134
      OS Version : 22H2
      OS Build : 19045.6159
      Plugins :
      CollectionInterface (1.1)
      ComparePlugin (2.0.2)
      ComparePlus (1.2)
      ConfigUpdater (2.0.1)
      DSpellCheck (1.5)
      GotoLineCol (2.4.5)
      HTMLTag (1.5.4)
      JSFunctionViewer (1.1)
      JSMinNPP (1.2503)
      JsonTools (8.4)
      mimeTools (3.1)
      MultiReplace (4.3.2.28)
      NppConverter (4.6)
      NPPJSONViewer (2.1.1)
      nppplugin_svn (3.0.1)
      NppToolBucket (1.10.6622.41516)
      PythonScript (2.1)
      RegexTrainer (1.2)
      SQLinFormNpp64 (6.25.1.15)
      urlPlugin (1.2)
      XBrackets (1.3.1)
      XMLNavigator (1.4)
      XMLTools (3.1.1.13)
        Alan Kilborn @Paul Leo
        @Paul-Leo
        The standard debug procedure for such a situation is to remove all plugins and try. If it doesn’t fail, you can re-add the plugins one by one (restarting between each addition) until you find the offending plugin.
        Paul LeoP 1 Reply Last reply Reply Quote 0
        • Paul LeoP
          Paul Leo @Alan Kilborn
          @Alan-Kilborn Thanks Alan. Was wondering about that. When/if I do find the plugin, should I post about it here, on this thread?
          Alan KilbornA Paul LeoP 2 Replies Last reply Reply Quote 0
            Surely!
            • Paul LeoP
              Paul Leo @Paul Leo
              @Paul-Leo Thanks, and sorry about missing the FAQ re: npp crashes after update/upgrade!
