    Collapse/Extend switch/case
    3 Posts 2 Posters 4.4k Views 2 Watching
    • francis BaudouxF Offline
      francis Baudoux
      Hello, in *.py or *.js file is it possible to collapse/extend ‘case’ block as for switch-if-else-… ?
      Thanks for help
        PeterJones @francis Baudoux
        @francis-Baudoux ,
        Python:
        match subject:
            case pattern1:
                # Code to execute if subject matches pattern1
                pass
            case pattern2:
                # Code to execute if subject matches pattern2
                pass
            case _:
                # Code to execute if no other pattern matches (the default case)
                pass
        So yes, Python will fold on case statements.
        JavaScript:
        switch (expression) {
          case value1:
            // Code to be executed if expression === value1
            break;
          case value2:
            // Code to be executed if expression === value2
            break;
          // ... more case clauses
          default:
            // Code to be executed if no case matches
        … doesn’t fold on case
        … BUT, that’s because it folds on BLOCKS, not STATEMENTS:
          case value1:
            break;
          case value2:
            break;
          default:
          francis Baudoux
          Hello,
          Thanks a lot for your great and swift answer
