    My first plugin development: CollectionInterface [was: Need help with getting started using C++ Plugin Template]
    68 Posts 8 Posters 28.5k Views
    • Lycan ThropeL
      Lycan Thrope @rdipardo
      @rdipardo ,
      I don’t disagree, but I just chose yours because yours has, like mine, a package of UDL, AC and FL, and it was one I tried to see in the UDL list that made me notice it, which is why it caught my attention, and @PeterJones has pointed out it’s not the focus of this testing.
      @PeterJones has also pointed out that he’s going to run check on the entire repository any way and address these issues, if his plugin is going to address automating installation of UDL’s into NPP, plus address the changes that have come about from the switching from the old way the files were referenced to the way they are now referenced for download by users. Nothing was meant @rdipardo by picking yours out, it was just a fluke that I found it and pointed it out, and the issue has been explained to me why, what I found happened.
        @Lycan-Thrope said,
        I have improved the validators, and was able to prove it would catch all the ones @rdipardo mentioned. I also confirmed it now catches the autoCompletion-filename-doesnt-match-UDL-internal-name. After verifying those worked, I updated the JSON to fix the non-XML repository: URLs, and updated the autoCompletion filenames to make them work correctly.
        v1.0.0-RC1
        • Use the correct autoCompletion filename
        • Ask for permission before overwriting existing XML files
        • Fixed some behind-the-scenes stuff compared to v1.0.0-beta
        I’m hoping to get the PluginList testing done soon, and to have submitted the v1.0.0 final version to the nppPluginList before Don closes submissions for NPP v8.8.
        Lycan ThropeL CoisesC 4 Replies Last reply Reply Quote 2
        • Lycan ThropeL
          Lycan Thrope @PeterJones
          @PeterJones ,
          This is definitely ready so far. I tested very late, as best I could, with both portable and standard and it works as needed. It downloaded VIM on the portable, so i took it over to the standard install and ran it again. It flagged the already existing files, and I told it to go ahead, and it paused at UAC, said that it was already installed, told it to go ahead and it did. On restart, VIM was visible in the UDL list.
          I can check more of the languages later, but I think it’s good to go for a RC version, and then add the needed improvements you’ve already documented from there.
          I need to get some sleep now. :-)
          • Lycan ThropeL
            @PeterJones ,
            Okay…another long night. Anyway, I used the portable to download that entire list that @rdipardo provided, and they all download just fine.
            Now, did you know or make it so we can download multiple languages and reboot just once to get them all installed? I know we can’t select mutliple, and download them, but after downloading a language, just going back to the list and selecting another one, allows you to continue downloading languages until they’re all done. I was doing one at a time and reboot and figured, what the heck, try and break it…but it didn’t, it worked. I even tried to redownload VIM package again, and it let me cancel each file and just continue downloading languages until I had them all done at once. I think that’s sufficient for now, being able to download more than one language at a time without rebooting.
            Anyway, if you want me to test it in the standard version, let me know. So far everything else has worked in both, but I can verify it if you want. Time for me to hit the sack again, and then I have to get back to taking my Learn C++ in 4 Hours video course, so I can be really dangerous. :-)
            • Lycan ThropeL
              @PeterJones ,
              Okay, just finished testing it in my 8.7.7 Standard install, and it all worked the same as in the portable, even after I canceled the VIM reinstall.
              I did make note this time, however, that I downloaded an excessive amount of UDL’s and since I haven’t looked in the code, there appears to be a limit of 30 UDL’s that can be displayed, other than the default User Defined Language menu dropdown and the User-Defined at the bottom of the Language menu dialog.
              Since you do check to see if a UDL is installed, might it make sense to notify the user that the limit of visible UDL’s that will be selectable in the Language list, has been reached, if there is a total number of 30 or more in the UDL directory? Even with the scrollable arrows, all that will show, is the 30 UDL’s and those two UDL texts mentioned above. I guess essentially 32 in that Language Dialog UDL section.
              Other than that finding, the 1.0 RC is ready for release and for others to nitpick additional features. <grin>
              • CoisesC
                Coises @PeterJones
                I notice your first release has Win32, x64 and ARM64 versions.
                How do you go about testing the ARM64 version? I’ve left that out of all my plugin work so far, because I haven’t a clue how to verify that it works at all.
                  PeterJones @Coises
                  @Coises,
                  I don’t. I’m following the time-honored tradition of releasing software untested, and hoping that any users will find edge cases for me. :-)
                  Given that it works as 32b and 64b on Intel processors, and I’m not doing anything that is out-of-the-ordinary, I am hoping that there aren’t any ARM64-specific bugs
                    Notepad++ v8.8.6 Plugins Admin links to CollectionInterface v1.2.0
                    • comes with Dark Mode support and bulk-mode download (actually from v1.1, which I mentioned over here)
                    • v1.2.0 has better handling of -settingsDir and Cloud Directory. (It was implementing the -settingsDir handling which lead to the new v8.8.6 plugin message NPPM_GETNPPSETTINGSDIRPATH , which my plugin uses when Notepad++ version is new enough (though it does have a workaround that works even if you manually install it on an older N++).)
                    CollectionInterface v1.3.0 is now available for manual installation:
                    • When downloading functionList defitions(s) (either on the FunctionList tab, or in bulk along with the UDL), the plugin will ask if you want to update the overrideMap.xml, which allows the functionList to be fully installed through the automatic process, so that functionList will immediately start working, without requiring you to manually update overrideMap.xml to link to the definition.
                    • I wasn’t fast enough with this feature to get it in the v8.8.6 Plugins Admin, so it’s manual installation only, for now.
