    Searching for between <STUFF> : Result goes beyond to include next argument
    3 Posts 2 Posters 103 Views
    • Saragrace KnaufS
      Saragrace Knauf
      Notepad++ v8.7.5 (64-bit)
      Build time : Dec 21 2024 - 05:13:03
      Command Line :
      Periodic Backup : ON
      Placeholders : OFF
      DirectWrite : ON
      Dark Mode : OFF
      OS Version : 24H2
      OS Build : 26100.2894
      Plugins :
      mimeTools (3.1)
      NppConverter (4.6)
      Fellow Notepad++ Users,
      Could you please help me the the following search-and-MARK problem I am having?
      Here is the data I currently have (“before” data):
      <td colspan="4" width="2000" height="304"><font size="2">I</font>n another life,
      Here is how I would like that data to look (“after” data):
      <td colspan="4" width="2000" height="304">  (I want just this highlighted)
      To accomplish this, I have tried using the following Find/Replace expressions and settings
      • Find What = <td .*>
      • Replace With = HIGHLIGHT/MARK
      • Search Mode = REGULAR EXPRESSION or NORMAL (tried both of these)
      • Dot Matches Newline = CHECKED or NOT CHECKED (I don’t see this option)
      HERE IS WHY YOU THOUGHT YOUR EXPRESSION WOULD WORK
      I understand why it is going beyond the first argument, I just don’t know how to limit it.
      Thank you in advance!
        PeterJones @Saragrace Knauf
        @Saragrace-Knauf ,
        .* is greedy
        Try .*? which is non-grredy
        Saragrace KnaufS 1 Reply Last reply Reply Quote 2
        • Saragrace KnaufS
          Saragrace Knauf @PeterJones
          .* is greedy
          Try .*? which is non-greedy
          That works perfectly. This also allowed me to go back to the instruction manual and find it. The “Multiplying Operators” threw me. I was looking for multiple characters after single characters!
