    View problem with break lines auto, bug?
    3 Posts 3 Posters 175 Views
    • Shinoda klS
      Shinoda kl
      See video of bug flickering monitor
      It happened when I put the comment in the ‘tipoFatura’ type key of the array
        PeterJones @Shinoda kl
        @Shinoda-kl ,
        Just posting a video isn’t very helpful to help us help you. But I’ve never seen anything as bad as what you showed in the video, so right now, the best I can say is “I cannot reproduce”
        Please share/answer the following:
        • share your ?-menu’s Debug Info
        • click the </> button while making your reply, and paste the smallest amount of example of PHP that causes the problem – and let us know what we can add/remove to make the problem appear/go away.
        • does it happen with other types of files, or just PHP?
        • what font are you using? does it still happen if you use another font?
          • actually, it might be easiest if you show a screenshots of Settings > Style Configurator > Language: Global Styles for Style: Default Styles and Style: Global Override
        • what is your Settings > Preferences > MISC > Use Direct Write? (And if you toggle that option and restart, does the problem still occur?)
        • mkupperM
          mkupper @Shinoda kl
          @Shinoda-kl Does the flicker only happen as you are moving the divider between the main text area and NppFTP? Does it happen if you make Notepad++ a window and use the dragger thing in the lower-right corner to resize the application?
          I installed the NppFTP plugin and saw one minor issue. When I move the divider line to the right there are many shadows of the divider that persistent for about 1/2 second but the screen goes back to normal. I never got the jitter that you are seeing.
          I then enabled word wrap which you seem to be using and there is a slight flicker at times as I drag the divider but no jitter. That prompted me to remove or uninstall NppFTP and to instead see what happens if I make npp a window and to resize it using the dragger in the lower-right corner and moving the mouse in a circle. There is some flicker as the word wrapping does its thing but I never got into a continuous jitter state.
          As times over the years I have had applications, including Notepad++ and Firefox, get into a state where it jitters much like what happens at times in your video. The issue is far more common with Firefox. It’s painting the screen and mid-way through painting the code that tries to fit things on the screen realized it’s painted its way into a virtual corner and so it starts painting again using slightly different parameters to get the text to fit, that also gets into a virtual corner and so it tries the first set of parameters again. There’s a loop of repainting two versions of the text.
          It’s rare for me and from what I recall tends to happen when I’m resizing an application or the dividers. I suspect it’s an edge condition in text drawing code. The workaround is easy in that I change the size or divider by a pixel.
          Reproducing on demand is not easy.
          If it’s a very common issue for you and you are willing to put some effort into creating a setup that one of us can 100% duplicate then we may be able to write up steps that allow one of the Notepad++ developers to get the application into the jitter state while also trying to fully understand what bit of code has the edge condition.
