    How to find words with 12 or more alphabets that are between a <li style...........> and </li>
    19 Posts 3 Posters 4.3k Views 1 Watching
    • dr ramaanandD Offline
      dr ramaanand
      Block of text for testing:-
      <div class=“right”>
      <ol>
      <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: "verdana"; font-size: 18px; color: black;”><div class=“marginleft”>Haemorrhoids <br>- piles</div></li>
      <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: "verdana"; font-size: 18px; color: black;”><div class=“marginleft”>Haemorrhoids<br>-piles</div></li>
      <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: "verdana"; font-size: 18px; color: black;”><div class=“marginleft”>Offensive haemorrhages</div></li>
      <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: "verdana"; font-size: 18px; color: black;”><div class=“marginleft”>CONSCIOUSNESS of womb. Hysterically inclined.</div></li>
      </ol>
      I tried this Regular expression to no avail:-
      <li style[^<>]*+>.*([a-z][a-z][a-z][a-z][a-z][a-z][a-z][a-z][a-z][a-z][a-z][a-z]).*</li>
      Haemorrhoids, haemorrhages, CONSCIOUSNESS and Hysterically should all be found/matched (the search should be case insensitive). Every other word with 12 or more alphabets should also be found/matched. Notice that I have put it in a capturing group for replacement
      • guy038G Online
        Hello, @dr-ramaanand and All,
        For your problem, I would use the second form of the generic regex, exposed in this post :
        https://community.notepad-plus-plus.org/topic/22690/generic-regex-replacing-in-a-specific-zone-of-text
        The SEARCH regex is (?-s)(?-i:BSR|(?!\A)\G).*?\K(?-i:FR)
        Note that the key-point, of that generic regex, is the use of the \G regex feature which means that a next match MUST begin right after the previous match !
        If we apply this generic regex to your practical search, it means that :
        • The BSR ( Begin Search region Regex ) is <li style=
        • The FR ( Find Regex ) is (?i)(\b[a-z]{12,}\b)
        Note that I changed the initial FR case-sensitive region (?-i:FR), embedded in a non-capturing group, by the case-insensitive region, embedded in group 1 (?i)(\b[a-z]{12,}\b)
        This leads to this functional regex, below, which solves your practical case :
        SEARCH (?-is:<li style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b)
        REPLACE RR
        Thus :
        • Put the INPUT text, below , in a new tab
        <div class=“right”>
        <ol>
        <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”><div class=“marginleft”>Haemorrhoids <br>- piles</div></li>
        <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”><div class=“marginleft”>Haemorrhoids<br>-piles</div></li>
        <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”><div class=“marginleft”>Offensive haemorrhages</div></li>
        <li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”><div class=“marginleft”>CONSCIOUSNESS of womb. Hysterically inclined.</div></li>
        </ol>
        • Move to the very beginning of the file
        • Open the Find or Replace dialog
        • Uncheck all the box options
        • Check the Wrap around option
        • Click, several times, on the Next button to verify the different matches or click, once only, on the Replace All button for a global replacement
        Note : if your text may contain accentuated characters, I advice you to prefer this version :
        • SEARCH (?-is:<li style=|(?!\A)\G).*?\K(?i)(\b[\u\l]{12,}\b)
        dr ramaanandD 1 Reply Last reply Reply Quote 1
          dr ramaanand @guy038
          @guy038 The word/term, “Hysterically” is not found/matched, probably because it is the second word with 12 or more alphabets in the same line. Can you tweak that RegEx to help find such words?
          dr ramaanandD 1 Reply Last reply Reply Quote 0
            dr ramaanand @dr ramaanand
            @guy038 (?-is:<li style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b).*?\K(\b[a-z]{12,}\b) helps find/match only the second word/term with 12 or more alphabets. So I can probably use this RegEx and make changes and then use what you gave to find the first word/term with 12 or more alphabets.
            • guy038G Online
              Hi, @dr-ramaanand and All,
              I don’t understand ! With the (?-is:<li style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b) regex, once the search regex has matched the word CONSCIOUSNESS, if you click again on the Find Next button, it does find the word Hysterically !
              If it’s not the case just post the EXACT raw text used
              You do not need your second version !
              P.S. : if your strings <li style= always begin a line, you may narrow down the results with this version :
              • SEARCH (?-is:^<li style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b)
                @guy038 It doesn’t begin at the start of the line, so I will not use your last RegEx (just above this response of mine). At regex101.com your Regular Expression does find that second word/term with 12 or more alphabets (see https://regex101.com/r/Dw8XTK/1) but it doesn’t on my laptop. It may be due to a bug but I will manage - I don’t want to waste your time. Thanks for your help and time!
                  @guy038 I have another block of text for testing as follows:-
                  <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Haemorrhoids <br>- piles</span>
                  <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Haemorrhoids<br>-piles</span>
                  <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Offensive haemorrhages</span>
                  <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>CONSCIOUSNESS of womb. Hysterically inclined.</span>
                  The Regular expression (?-is:<span style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b).*?\K(\b[a-z]{12,}\b) does not find/match anything
                  dr ramaanandD 1 Reply Last reply Reply Quote -1
                    @guy038 (?-is:<span style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b) however does find/match it
                      @dr-ramaanand said in How to find words with 12 or more alphabets that are between a <li style...........> and </li>:
                      How to make the searching stop upon encountering a </span>?
                        @guy038 The regular expression (?-is:<span style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b).*?<\/span> helps find words of 12 alphabets or more between <span style=.....>and </span>. Is it correct?
                          <p style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Confirmatory symptoms</p>
                          <ol><li style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>REMEDY RELATIONSHIPS</li></ol>
                          Everything after the </span> should be skipped
                            @guy038 Tweaking your RegEx above to (?-is:<span style=|(?!\A)\G).*?\K(?i)(\b[a-z]{12,}\b) helped find the first word with 12 or more alphabets that are between a <span style…> and </span>.
                            Someone at https://regex101.com tweaked it to (?-i:<span style=[^>]*+>|(?!\A)\G)(?>[^<>\w]++|<(?!\/?span\b)[^>]*+>|\b\w{1,11}\b)*+\K(\b[a-z]{12,}\b) which also helped find the first word with 12 or more alphabets that are between a <span style…> and </span> on my laptop but for them (and probably, even you) you are able to find/match the second word with 12 or more alphabets that are between a <span style…> and </span> also. I think this is a Notepad++ bug
                            PeterJonesP dr ramaanandD 2 Replies Last reply Reply Quote 0
                            • PeterJonesP Online
                              PeterJones @dr ramaanand
                              Remember, regex101 is not specific to the Boost regex engine, which is the engine that Notepad++ uses. They might not be answering you with the Boost specifics in mind (though I haven’t read your discussions over there, so maybe they really are answering w/r/t Boost / Notepad++).
                              Every regex engine has its own design decisions, and just because the Boost regex design decisions are different than the engines they deal with does not mean that it’s a bug in Notepad++ (and if it is a bug in Notepad++, it would presumably be inherited from Boost regex, not inherent to Notepad++ itself, as far as I understand things).
                                (?-i:<span style=[^>]+>|(?!\A)\G)(?>[^<>\w]++|<(?!/?span\b)[^>]+>|\b\w{1,11}\b)*+\K(\b[a-z]{12,}\b)
                                @PeterJones The person who helped me with the above RegEx at https://regex101.com was kind enough to send me a screenshot of his results with Notepad++ which found/matched every word of 12 alphabets or more but on my laptop, it found/matched only the first word of 12 alphabets or more between <span............. and </span>
                                  @dr-ramaanand
                                  That means you obviously did something differently than he did, or you did not describe your data correctly to him. Oddly enough, the same thing happens here when Guy and the others try to help you here.
                                  Calling it a “bug” in Notepad++, at this point, seems a rather premature conclusion on your part.
                                  I took your most-recent data (from this post) along with the regex that you got from regex101, and it replaced all the instances of twelve-or-more-letter words for me. So I would agree with the regex101 , that the regex works.
                                  Here are some screenshots: I start with the data pasted from your post, then I use the regex shown and use Replace All, and I see
                                  • this:
                                  • get converted into:
                                  The five replacements are correct
                                  Remember, with ANY regex that uses \K (which this one does), it will not work with single Replace – you must use Replace All
                                  So, if the data looks like the data you most-recently shared here, then the regex works to transform your data by using Replace All. If your data does not look like what you shared here, then all bets are off, and all I can do is reiterate what others have told you: regex alone is the wrong tool for editing HTML.
                                  • guy038G Online
                                    Hello, @dr-ramaanand, @peterjones and All,
                                    @dr-ramaanand, you’re trying to use this regex (?-i:<span style=[^>]+>|(?!\A)\G)(?>[^<>\w]++|<(?!/?span\b)[^>]+>|\b\w{1,11}\b)*+\K(\b[a-z]{12,}\b)
                                    But this one, much more simple, (?-is:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b) does EXACTLY the same search and find the same matches !!
                                    It comes from the second form of my generic regex, discussed in this post :
                                    https://community.notepad-plus-plus.org/topic/22690/generic-regex-replacing-in-a-specific-zone-of-text/1
                                    where I said, textually :
                                    When the BSR and the different matches of the FR regex are all located in a single line, any line-ending char(s) will implicitly break down the \G feature. The ESR part is then useless and the generic regex can be simplified into :
                                    SEARCH (?-s)(?-i:BSR|(?!\A)\G).*?\K(?-i:FR)
                                    REPLACE RR
                                    Thus, @dr-ramaanand, just stay concentrated on the black zones to modify, in order to form a valid expression !! Do not try anything else, which is, finally, more complicated !!
                                    So, if we just replace the BSR zone by <span style= and the FR zone by \b[a-z]{12,}\b, we end up with the valid SEARCH regex, below :
                                    • SEARCH (?-s)(?-i:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b)
                                    Which I just simplified as :
                                    • SEARCH (?-si:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b)
                                    And, given your INPUT text :
                                    It would match, as @peterjones said, the five strings Haemorrhoids, Haemorrhoids, haemorrhages, CONSCIOUSNESS and Hysterically which all contain 12 or 13 chars
                                      @guy038 @PeterJones It looks like I was using an old, earlier version of Notepad++. I have now installed the v8.7.4 (32 bit) version of Notepad++, released on December 4th, 2024. The RegEx (?-si:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b) does not stop searching/finding matches of words with 12 or more letters/alphabets after a </span> but (?-s)(?-i:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b) and (?-i:<span style=[^>]*+>|(?!\A)\G)(?>[^<>\w]++|<(?!\/?span\b)[^>]*+>|\b\w{1,11}\b)*+\K(\b[a-z]{12,}\b) do. Thanks a lot for your time.
                                      • guy038G Online
                                        Hi, @dr-ramaanand, @peterjones and All,
                                        @dr-ramaanand, I don’t think that your old version was a problem, regarding the results of these regexes !
                                        You said, in your last post :
                                        The RegEx (?-si:<span style=|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b) does not stop searching/finding matches of words with 12 or more letters/alphabets after a </span> …
                                        Sorry to contradict you but, given your INPUT text, below :
                                        My regex DOES find the five words Haemorrhoids, Haemorrhoids, haemorrhages, CONSCIOUSNESS and Hysterically, as well as the two other regexes you mentionned !
                                        But, as I said in my previous post, this syntax only works if the BSR region and all the matching words lie in the current line, before an other <span style= syntax beginning the next line
                                        Now, let’s use this new INPUT text, pasted in a new tab, where I added some HTML paragraphs, after the </span> tag of each line
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Haemorrhoids <br>- piles</span> <p>The words abbreviation and fabrications are long</p>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Haemorrhoids<br>-piles</span> <p>This radioacoustics</p>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>Offensive haemorrhages</span> <p>Words nanofabrications and calligraphically contains 16 letters</p>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “verdana”; font-size: 18px; color: black;”>CONSCIOUSNESS of womb. Hysterically inclined.</span> <p>Echocardiographies and Neovascularization</p>
                                        This time, we cannot apply the same regex as some words, located after </span> would also be detected !
                                        Indeed, the additional words abbreviation, facrications, radioacoustics, nanofabrications, calligraphically, Echocardiographies and Neovascularization are not wanted !
                                        Thus, we must use the first form of my generic regex, described in this post :
                                        SEARCH (?-si:BSR|(?!\A)\G)(?s-i:(?!ESR).)*?\K(?-si:FR)
                                        With :
                                        BSR = <span style=
                                        ESR = </span>
                                        FR = \b[a-z]{12,}\b
                                        Leading to this functional regex :
                                        SEARCH (?-si:<span style=|(?!\A)\G)(?s-i:(?!</span>).)*?\K(?i:\b[a-z]{12,}\b)
                                        Remark : I also changed the part (?-si:, before FR, by simply (?i:, in order to find any word of more than 11 letters whatever its case !
                                        And again, it would just match the five words Haemorrhoids, Haemorrhoids, haemorrhages, CONSCIOUSNESS and Hysterically, which come BEFORE </span> :-))
                                        Now, let’s get back to your original INPUT text, where I simply changed the name of the font by an other name with more than 11 letters : the DejaVuSansMono font !
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “DejaVuSansMono”; font-size: 18px; color: black;”>Haemorrhoids <br>- piles</span>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “DejaVuSansMono”; font-size: 18px; color: black;”>Haemorrhoids<br>-piles</span>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “DejaVuSansMono”; font-size: 18px; color: black;”>Offensive haemorrhages</span>
                                        <span style=“padding: 0px; list-style-type: decimal; list-style-image: none; list-style-position: outside; font-family: “DejaVuSansMono”; font-size: 18px; color: black;”>CONSCIOUSNESS of womb. Hysterically inclined.</span>
                                        If I use the last regex of my previous post :
                                        Against the INPUT text just above, it would wrongly match the name of the font, four times :-((
                                        We can solve this problem by changing the BSR search region ! Instead of <span style=, we’ll rather use <span style=.+?>
                                        Hence, this new version :
                                        (?-si:<span style=.+?>|(?!\A)\G).*?\K(?i:\b[a-z]{12,}\b)
                                        Or this one :
                                        (?-si:<span style=.+?>|(?!\A)\G)(?s-i:(?!</span>).)*?\K(?i:\b[a-z]{12,}\b), in case of possible words after </span> and/or multi-lines results
                                          @guy038 Oui, merci beaucoup!
