    Problem opening PHP links with single quotes
    3 Posts 3 Posters 591 Views
    • David BaezD
      David Baez
      When I double-click a PHP link, it opens with a single quote at the end of the URL.
      <?php $url = 'https://google.com';
      What settings do I need to adjust in Notepad++ to ensure it opens correctly?
      Thank you.
      rdipardoR 1 Reply Last reply Reply Quote 1
      • rdipardoR
        rdipardo @David Baez
        This was supposed to be fixed in the 8.6.6 release:
        Fix URL enclosed in apostrophes or backtick not working issue
        You should open a GitHub issue.
          PeterJones @rdipardo
          @rdipardo said in Problem opening PHP links with single quotes:
          Well, @David-Baez, if you are still on an earlier version (especially one before v8.6.6), then first try upgrading Notepad++ and see if that fixes it. If you are already on v8.7, then I agree with @rdipardo that you should file a GitHub issue (this FAQ explains how, if you don’t already know)
