    How to keep paragraph reduced
    3 Posts 2 Posters 375 Views
    • Raphaël AldhariR
      Raphaël Aldhari
      Hello, I’m mostly using basic notepad functions.
      Is anybody know if there is a way to keep my paragraph reduced even if I close and open the file again (not just closing/reducing Notepad itself) ? (+ and - in the example)
      Thank you !
        Alan Kilborn @Raphaël Aldhari
        @Raphaël-Aldhari said in How to keep paragraph reduced:
        The only way is to keep the file as part of a “session”. For the default session, the answer is simple – keep the file open in a tab, i.e., don’t close it.
        Raphaël AldhariR 1 Reply Last reply Reply Quote 1
        • Raphaël AldhariR
          Raphaël Aldhari @Alan Kilborn
          Thank you, I didn’t know the session part, it will be useful !
          Have a good day
