    copy and paste problem
    6 Posts 2 Posters 1.7k Views
    • ohlogicO
      ohlogic
      I am having a problem with the copy and paste.
      This does not happen when I use Notepad++ locally on my computer.
      Because I often use Notepad++ over a x2goclient session. This is the problem.
      I often have to copy selected code more than once, e.g., two times, before the paste option is available.
      This seems to happen when I change the selected line. If the paste is available when I change the selected line, the data is still available. This is ok.
      However, whenever I change the selected line, as in what line number I am currently on, then attempt to copy some data on that line, I have to copy it twice before it is available for paste.
      Please help, thank you.
      Notepad++ v8.6.9 (64-bit)
      Build time : Jul 12 2024 - 05:09:25
      Command Line : /var/path/mysql.php -nosession -multiInst
      Admin mode : ON
      Periodic Backup : OFF
      OS Build : 19043.0
      WINE : 9.15
      Plugins :
      mimeTools (3.1)
      NppConverter (4.6)
        PeterJones @ohlogic
        @ohlogic ,
        Notepad++ itself doesn’t need to copy data twice in order to have it in the clipboard. That tells me that the chances are high that it’s caused by your remote-access client (x2goclient), not by Notepad++. If the same thing happens if you run MS notepad.exe over the same client, then it’s definitely x2goclient’s fault; if it doesn’t, then it still might be the client’s fault, or the unique way that the client interacts that Notepad++ gets confused by.
        ohlogicO 1 Reply Last reply Reply Quote 1
        • ohlogicO
          ohlogic @PeterJones
          @PeterJones Here’s the thing, when I start a program like xed or notepad.exe, they copy and paste just fine over the x2goclient session. This copy, past problem is only happening in notepad++ via wine over x2golient. I have been a Notepad++ enthusiast for many years, I may have to start using an alternative text editor until this is resolved. Though Notepad++ is the best text editor and is my favorite always.
            PeterJones @ohlogic
            @ohlogic said in copy and paste problem:
            via wine
            That’s probably your problem. Notepad++ developers don’t actually support Notepad++ on wine, because that layer adds things that Notepad++ developers cannot guarantee. If you can get it to work on wine, great; if not, sorry.
            ohlogicO 1 Reply Last reply Reply Quote 0
            • ohlogicO
              ohlogic @PeterJones
              @PeterJones Yes, I can confirm that the latest version of wine is causing this, I have installed wine version 6.0.1 x64 that is the recommended version from PlayOnLinux to install different versions of wine and Notepad++, and it works nicely again. Thank You for your assistance.
              • ohlogicO
                ohlogic @ohlogic
                @ohlogic It seems that a different wine version did not suffice, though installing Diodon, a clipboard manager, seems to be ok for now, if anything changes, I’ll update this post. Good day.
