    HTML code not running properly
    3 Posts 2 Posters 206 Views
    • Amir CA
      Amir C
      Im new at using html and notepad++ so any help would be greatly appreciated
      • CoisesC
        Coises @Amir C
        This has nothing to do with Notepad++.
        However, since it’s easy enough to find four errors right away:
        Line 14 is surely meant to be </style>.
        You’re missing a quote mark after id= in line 27.
        Line 30 should be </html> (note the diagonal).
        You need to save as a filename ending in .htm or .html, not .txt.
        Amir CA 1 Reply Last reply Reply Quote 4
        • Amir CA
          Amir C @Coises
          @Coises
          Oh I see went back and fixed those errors and it’s working now appreciate it
