    Not using %appdata% when installing via CLI
    2 Posts 2 Posters 559 Views
    • I
      ITManders
      Hi,
      I’m trying to silent install Notepad++ with the option to not use %appdata% using the command line interface, but i can’t seem to find a way to select the “don’t use %appdata%” option without using the installer.
      Is it possible to silent install while also not using %appdata%?
      This is the command i’ve been using to silent install:
      npp.8.6.7.Installer.x64.exe /S /D=C:\Notepad++
      Here’s the debug info:
      Notepad++ v8.6.7 (64-bit)
      Build time : May 12 2024 - 20:04:00
      Path : C:\Notepad++\notepad++.exe
      Command Line :
      Periodic Backup : ON
      OS Version : 23H2
      OS Build : 22631.3672
      Plugins :
      mimeTools (3.1)
      NppConverter (4.6)
        PeterJones @ITManders
        @ITManders said in Not using %appdata% when installing via CLI:
        Sorry, as far as I’ve ever seen, that is not currently one of the installer options. One would have to request that feature by following the instructions in our feature request FAQ
