    I need help with downloads
    4 Posts 2 Posters 249 Views
    • A
      awmess34x
      I’ve used Expression Web 4 to maintain my website from my windows desktop PC and from my windows laptop PC.
      I also use Notepad++ for shorter changes but I’m unable to download a file – apparently if it’s been altered on both PCs in the past.
      The message I get is “Do you want to reload it” but it won’t reload whatever response I make.
      Any ideas?
        PeterJones @awmess34x
        @awmess34x said in I need help with downloads:
        How are you using Notepad++ to “download a file”? Are you connecting with NppFTP plugin? The message you describe doesn’t sound like an NppFTP plugin message. You will need to be more specific as to exactly what you’re doing with Notepad++ and which plugin(s) (if any) you are using to accomplish the task
        A 1 Reply Last reply Reply Quote 1
        • A
          awmess34x @PeterJones
          Notepad++ v8.6.7 (64-bit)
          Build time : May 12 2024 - 20:04:00
          Command Line :
          Periodic Backup : ON
          OS Version : 23H2
          OS Build : 22631.3672
          Plugins :
          mimeTools (3.1)
          NppConverter (4.6)
          NppFTP (0.29.8)
            @awmess34x ,
            Okay, you have the NppFTP plugin. That still doesn’t tell us your actual steps that you are using that are resulting in the message.
            You would have to tell us what steps you are actually taking inside Notepad++ (every action that leads up to this problem); it would be good to have the NppFTP Messages window open, and see if it shows any errors during the process, and then tell us about those.
            Without more from you, it’s impossible for me to help you. But maybe someone else can make a guess based on your description and be able to help you without you supply more information (I doubt it, but I’d love to be proven wrong on this).
            Good luck.
