    Need help for CNC code.
    6 Posts 6 Posters 2.0k Views 2 Watching
    • Radomir StojanovićR Offline
      Radomir Stojanović
      Greetings to everyone! I’m a newbie here, hoping to get some answers to a few questions. I began CNC programming using Solid Works 2018, a program designed for writing CNC code with a generic post-processor. I want to share my problem with you.
      (Generic text “GENERIC TEXT” GENERIC TEXT, )
      (GENERIC TEXT, generic text. )
      N1 G00 G90 G17 G40 G80 G71
      N2 (12MM CRB 2FL 25 LOC)
      N3 X25.4 Y25.4 T03 M06
      N4 G75 S2000 M03
      N5 G90 G54 G00 X13.539 Y10.764
      N6 Z3.
      N7 G01 Z-10. F400. M08
      N8 G41 X17.951 Y6.351 F150.
      N9 G03 X18.8 Y6. I18.8 J7.2
      N10 G01 X20.
      N11 X40. F100.
      N12 G02 X46. Y0 I40. J0
      N13 G01 Y-40.
      N14 G02 X40. Y-46. I40. J-40.
      N15 G01 X0
      N16 G02 X-6. Y-40. I0 J-40.
      N17 G01 Y0
      N18 G02 X0 Y6. I0 J0
      N19 G01 X20.
      N20 X21.2
      N21 G03 X22.049 Y6.351 I21.2 J7.2
      N22 G40 G01 X26.461 Y10.764
      N23 G00 Z3.
      N24 Z25. M09
      N25 M05
      N26 M02
      This is the code that I got. I have to rewrite it like this in order for machine to work:
      N0 %
      N1 G00 G90 G40
      N4 G75 S2000 M03
      N5 G90 G00 X13.539 Y10.764
      N6 Z3.
      N7 G01 Z-10. F400 M08
      N8 G40 X17.951 Y6.351 F150
      N10 G01 X20.
      N11 X40. F100
      N13 G01 Y-40.
      N15 G01 X0
      N17 G01 Y0
      N19 G01 X20.
      N20 X21.2
      N23 G00 Z3.
      N24 Z25. M09
      N25 M05
      N26 M02
      N27 E
      This is my problem.
      I have a recurring issue with the beginning and end of my code. I always have to replace the generic text with ‘%’ and manually add an ‘E’ at the end of the program whenever I rewrite it. Is there a way to automate this process?
      Whenever I get a new program, I have to correct F400. F200. (or any Fxxx. not to have a period at the end of Fxxx). Can I automate that as well?
      mkupperM Michael VincentM Terry RT 3 Replies Last reply Reply Quote 0
      • mkupperM Offline
        mkupper @Radomir Stojanović
        @Radomir-Stojanović - I believe this article applies FAQ: You’ve asked your question in the wrong place!
        This forum is for supporting the Notepad++ text editor, and to a lesser extent, the regular expression system implemented by Notepadd++ plus some of the Notepad++ plugins.
          I think this is the right place for this question.
          It is about how to transform this text:
          into this text:
          Note that I’ve intentionally shown the two texts as a “diff”.
          • Michael VincentM Online
            Michael Vincent @Radomir Stojanović
            @Radomir-Stojanović
            Is this plugin related, or just a search/replace macro question?
            • Terry RT Offline
              Terry R @Radomir Stojanović
              @Radomir-Stojanović said in Need help for CNC code.:
              This can easily be done with 3 regular expressions (regex), however the 3rd one won’t be completely sorted, I will speak to that later.
              So using the Replace function we have the first one which deals with the “generic text issue”.
              Search mode must be regular expression for all 3 regex I’m showing.
              Find What:(?-s)\A(\([^)]+\)(\R))+
              Replace With:N0 %${2}
              Click on Replace All
              Now we deal with all the Fxxx. sequences.
              Find What:(F\d+)\.
              Replace With:${1}
              Again click on Replace All
              Finally the end line for the code. The primary problem here is that regex cannot count. So there isn’t an easy way for the regex to add 1 to the last line and write a new line with the incremented number and and E. So what my regex does is to write it with xx as the line number. So you would still need to change the xx for the real line number. Although I have provided this regex, I think it would be of limited value as you would still need to edit that last line.
              Find What:(?-s)(\R).+\K\z
              Replace With:${1}Nxx E
              These 2 (or 3) regex can be combined into a macro which is essentially the keystrokes recorded as you type them and once saved (with a name) can be re-run whenever you wish.
              robertjunior24R 1 Reply Last reply Reply Quote 2
              • robertjunior24R Offline
                robertjunior24 @Terry R
