Problem launching NPP with file from IDE
@Lycan-Thrope said in Problem launching NPP with file from IDE:
The space in the path, is being passed to NPP. It’s refusing to properly open the file that is pointed to, because of that space.
The same is true if you typed that from cmd.exe. The dBASE IDE needs to send it with quotes around the filename, because that is the correct way of generating a windows command line command for any command that includes a space inside one of the arguments
Without the quotes around the path, notepad++ cannot and will not work. This is how Notepad++ has always been designed.
Think of it this way: create four files in the same directory
blahwithspace.txtblah with space.txt
Run
notepad++ blah with space.txtin that directory. Notice it opens the three individual files, not the file with spaces in the name. Now runnotepad++ "blah with space.txt", and it opens the single file with spaces in its name. Notepad++ needs the quotes around the parameter to tell it that it’s a single parameter, not three.If you cannot make dBASE IDE send the path properly quoted, the fault lies with dBASE IDE, not with notepad++, because those quotes are the ONLY way that Notepad++ (or any other application) can correctly disambiguate the three-file vs one-file versions I showed above.
update: Microsoft’snotepad.exe(at least the windows10 version; maybe not the tabbed “app” in windows11) treats everyone afternotepad.exeas a SINGLE filename, including any spaces typed; but it can get away with that, because there is no way to open multiple files with one call tonotepad.exe. That’s probably whynotepad.exe“worked” from dBASE. And in my four-file example, whether or not you include quotes,notepad.exewill open the file-with-spaces, not the three individual files.update 2: if dBASE is incapable of creating a properly quoted command string, then write a .bat wrapper, where the contents of the .bat are just
"c:\program files\Notepad++\notepad++" -udl=Dark_dBASEPlus "%*", which has the effect of wrapping all the space-separated tokens from the unquoted command line, and passing them all to Notepad++ with the correct quotes. -
@PeterJones ,
It appears that the multiple file capability is the reason, then, from what I can see, that the spaced name, can’t be open meaning it is NPP specific. :-)I saw your response, as I was going to post what is one of my workarounds without removing the spaces in directory names which has us create a template in the Command Window and name the file, which bypasses the space issue, as the Command Window already is pointed to the proper directory, and then only needs to send the filename to be opened.
This is a screenshot of the IDE’s Abbreviations template, similar to the Snippet capability in NPP, to enter a file name to open the file:
And this is the resultant debug info:
Notepad++ v8.6.5 (64-bit)
Build time : Mar 29 2024 - 17:04:43
Command Line : baseform.cfm -udl=Dark_dBASEPlus
Periodic Backup : ON
OS Name : Windows 10 Home (64-bit
OS Version : 22H2
OS Build : 19045.4291
Plugins :
CodeAlignmentNpp (14.1.107)
ColumnsPlusPlus (1.0.2)
ComparePlus (1.1)
CSVLint (0.4.6.6)
CsvQuery (1.2.9)
EnhanceAnyLexer (1.4)
MarkdownViewerPlusPlus (0.8.2)
mimeTools (3.1)
NppConverter (4.6)
NppExec (0.8.4)
NppPluginDemo (4.3)
NppSnippets (1.7.1)
NppUISpy (1.2)
PythonScript (2)
TakeNotes (1.2.6)
XMLTools (3.1.1.13)So I guess it’s NPP’s ability to open multiple files in a command line, is what makes it a problem for my usage. That’s why I asked if there was some kind of commandline switch that could alter the NPP parsing of spaces in a filepath passed to it, because since NPP is a Win only editor, it would seem that the ability to accept longnames in filepaths that may include spaces would be a builtin mechanism, since as far as I know, every Windows filename tends to have a filename extension, whether it’s visible or not, and that would seem to be to me, a dead give away upon parsing a filepath that the actual filename has not yet been reached.
Every Windows site with any clout recommends to always pass command line arguments that have spaces with quotes around them. It’s not just for Notepad++. Try running a script name
script with spaces.pyorscript with spaces.plwith your favorite interpreter, without putting quotes around it, from the command line. See what happens. Try another editor that handles multiple files from the command line (MS notepad doesn’t count, at least not in Win10 – try scite, which I just confirmed; try some other editor that you have access to; see what happens).In fact, in cmd.exe, try
notepad++ blah<TAB>to get it to autocomplete, and note that even microsoft is smart enough that if the filename has spaces, it wants to put quotes around it.If you cannot make dBASE properly quote the file names, then you will need to come up with a way to get around that limitation in dBASE – whether it’s by using just the filename, as you showed, or a batch wrapper, like I showed.
update: add images:
@PeterJones ,
I’m going to try the batch wrapper, and see if it works, so thanks for that clue option. I just can’t see forcing people to change their naming, which is why I asked if there was a command line switch, but if a bat will make it work, all the better as it doesn’t force people to change, but makes the process work.Just by chance, because of that problem with spaces I never really got in the habit of creating filenames with spaces, but obviously became lax when it came to this directory naming issue with spaces since for most things, it has been able to work, since the DOS days. :-) I guess I’ll have to reinforce my habit for directory names as well, but if I hadn’t become lax, this issue wouldn’t have been found and someone else would have been scratching their head. :-)
Update: Yes, it works, similar to my work around template in the command window, so thank you for that, as I can offer that as an additional option beyond just making sure there are no spaces in filepath/filename or using my template. The two simple options is the .bat file or removing spaces as the least work required to launch a file from the IDE.
Windows has always said to use quotes around filenames that have spaces, when passing them as command-line arguments. The same is true on Linux. The problem is that certain applications (like dBASE IDE, apparently) do not properly use that rule when generating commands. It’s even documented in win32 API: CreateProcess
This is nothing new, and nothing that Notepad++ is “forcing” on anybody. It’s the way that Windows works, despite poorly written applications giving examples to the contrary.
@PeterJones ,
Well, I don’t know about poorly written. The screenshot does show, that the IDE does enclose the path with quotes when it does have spaces, and doesn’t when it doesn’t in the command window when launching SciTE, just by chance, however, SciTE opened 3 empty documents instead of the one desired to be open.
So if I do the same with NPP, it just doesn’t open the files without my allowing it to via the error dialogs but it does open to the correct directory, if not the file. In this screenshot, you see the set command and that is me setting the External Editor Dialog to first the SciTE editor and the second one sets it to NPP, and then again attempting to open the same files. One is quoted, but it is the errored out spaces, and the other opens just fine, and has no quotes…so maybe you can see why I may be seeing that there is two different editor responses happening at the same time.
The question is, are these the strings that are being passed to the editors and I suspect they are, and if they are properly formed with quotes, why are they not performing properly.
Update1: The
modify commandyou see is the interpreters way of showing that a file was right clicked andOpen in Source Editorselected from the IDE right click menu option. -
No, they are not. Your Debug Info proved that. If you don’t believe Debug Info, use Task Manager’s Command Line column in the Details tab. (Right click on the header, Select Columns, and choose Command Line, if it’s not visible for you.)
@PeterJones said in Problem launching NPP with file from IDE:
Hmmm…going to have to look into that, if I can. It’s not open source, so that may be difficult to find out. :(
I don’t seem to be able to find this option. (learning everyday) I have the details tab, but don’t seem to be able to bring up Command Line or any column. Will still try, but at the moment, this doesn’t seem to be something I’m able to do at the moment. ::sigh:: more learning. ;)
Update: Perhaps because my McAfee’s was running it was blocking something, I managed to right click the header and get Columns to show, but I don’t see an option checkbox for Command Line.
Update2: found it. investigating now. :)
Update3: You’re right, it apparently isn’t passing it to NPP quoted, but the command to run NPP IS quoted. Hmmm…
@PeterJones ,
Thanks for helping me find this out. This is strange, because when we put filepath/filename in the code, we do surround them with quotes for the reasons you point out.Why the IDE would not pass a filepath/filename parameter without quotes around it is strange, unless the way the IDE is designed, it does it internally, as witnessed by those two different ways it displays depending on if there is spaces in it. In other words, the IDE interpreter sees the spaces, and then puts quotes around it for itself. This makes sense, but making it more difficult for us to use external editors without passing it that way is definitely perplexing. Just as an FYI, the dBASE Plus editor is based on the SciTE editor that they changed to in the dBASE Plus 9 version, so it does share at least a little bit of familial genes with NPP, namely the Scintilla library. :-)
