    Column mode smart selection shortcut
    11 Posts 7 Posters 5.8k Views 2 Watching
    • notdodgeballN Offline
      notdodgeball
      I’m trying to find a way to improve my usage of the Column mode option, thus I’m in the need of something like this:
      a
      Basically, move the carret up (or down) until it hits the “top” (or “bottom”) so I don’t have to press Alt+Shift that many times, or use the mouse, god forbid. A “smart” column mode selection if you will. It would be even more helpful if also worked like that:
      In other words, move upwards until either the line doesn’t go that far or the left or right character is different from those at the initial position. Or at least it’s how I think a script should handle it. Yes, a script, I think that’s the only way… Although it would be nice to have it as a standard feature, I’m sure other people would find it useful.
      So before I dabble in python or lua or something, if anyone could point me in the right direction, preferably a easier way or “it’s already been done, stupid” I’d appreciate.
        Alan Kilborn @notdodgeball
        @notdodgeball said in Column mode smart selection shortcut:
        Well, there’s this that may help:
        User manual ref..
          notdodgeball
          Ok, my first python script:
          if editor.getSelectionEmpty():
            currentLine = editor.lineFromPosition(editor.getCurrentPos())
            currentLineLength = editor.lineLength(currentLine)
            currentLineStart = editor.positionFromLine(currentLine)
            currentPos = editor.getCurrentPos()
            currentHorizontalPos = currentPos - currentLineStart
            currentChar = editor.getTextRange(currentPos, currentPos + 1)
            for x in range(1, 69):
              previousLineStart = editor.positionFromLine(currentLine-x)
              previousLinelength = editor.lineLength(currentLine-x)
              if editor.lineLength(currentLine-x) < currentHorizontalPos:
                break
              previousLineSamePosition = previousLineStart + currentHorizontalPos
              previousChar = editor.getTextRange(previousLineSamePosition, previousLineSamePosition + 1)
              if currentChar != previousChar:
                break
              else:
                editor.addSelection(previousLineSamePosition,previousLineSamePosition)
          There is better ways to do it, I assume, but it worked so far. Please tell me if there is something outstandingly bad.
          Alan KilbornA Mark OlsonM 2 Replies Last reply Reply Quote 0
            Probably this is a leading candidate:
            69
            • Mark OlsonM Offline
              Mark Olson @notdodgeball
              @notdodgeball
              To expand on why @Alan-Kilborn said the number 69 is “oustandingly bad”:
              It’s (usually) bad practice to include “magic numbers” like 69 in your code with no explanation as to why you chose that number. Better to declare a global constant (preferably with an explanatory comment) like so, and then reference it later on in the code:
              # I'm using a proprietary file format where every file has 69 lines
              MY_MAGIC_NUMBER = 69
              for x in range(1, MY_MAGIC_NUMBER):
              That may reduce your confusion weeks later when you stumble across this script and wonder what the hell it’s supposed to do.
                notdodgeball
                Yeah, I know, I thought putting it as 69 would make it clear but yes, you are right.
                Regardless, I was putting it into use and it’s actually worse than that. When the file has tabs, getCurrentPos() it does not line up as the position varies depending on the tabulation. How do circumvent it? I assume getColumn() might help looking at the docs. Hum…
                  notdodgeball
                    currentCol = editor.getColumn(currentPos)
                    currentRChar = editor.getTextRange(currentPos, currentPos + 1)
                    currentLChar = editor.getTextRange(currentPos, currentPos - 1)
                    count = 0
                    while True:
                      count += 1
                      previousLine = currentLine-count
                      previousLineStart = editor.positionFromLine(previousLine)
                      previousLineLength = editor.lineLength(previousLine)
                      previousPos = editor.findColumn(previousLine,currentCol)
                      previousCol = editor.getColumn(previousPos)
                      previousRChar = editor.getTextRange(previousPos, previousPos + 1)
                      previousLChar = editor.getTextRange(previousPos, previousPos - 1)
                      if currentRChar != previousRChar or currentLChar != previousLChar or previousCol != currentCol:
                        break
                      editor.addSelection(previousPos,previousPos)
                  • EkopalypseE Offline
                    Ekopalypse @notdodgeball
                    Shouldn’t that be 42 instead? ;-)
                    pbarneyP 1 Reply Last reply Reply Quote 4
                    • pbarneyP Offline
                      pbarney @Ekopalypse
                      @Ekopalypse said in Column mode smart selection shortcut:
                      That just selects everything. And by “everything,” I mean everything: life, the universe, etc.
                      chdikie hensleyC 1 Reply Last reply Reply Quote 3
                      • chdikie hensleyC Offline
                        chdikie hensley @pbarney
                        • PeterJonesP Online
                          PeterJones @chdikie hensley
