    help! regular express
    2 Posts 2 Posters 633 Views 1 Watching
    • 李唯任李 Offline
      李唯任
      Hello, I want to add brackets around multi-line text
      before
      some text
      some text
      some text
      after
      some text
      some text
      some text
      • guy038G Online
        Hello, @李唯任 and All,
        Not difficult with regular expressions !
        • Do a normal selection of your first text part to modify
        • Untick all box options
        • Tick the Wrap around box option
        • Enter (?-s)(?:.+(\R))+.+ in the Find what: zone
        • Enter {\1$0\1}, in the Replace with: zone
        • FIRST possibility :
          • Tick the In selection box option
        • SECOND possibility :
          • Do not tick the In selection box option
          • Click on the Find Next button
          • Click on the Replace button if the present selection must be replaced (A)
          • Click again on the Find Next button, if the present selection must stay unchanged
          • Return to line (A)
          • And so on…
        => the FIRST possibility just produce one global replacement on your selection whereas the SECOND possibility allows you to choose the zones of text to modify or not !
        Notes :
        • First, the in-line modifier ( (?-s) ) means that the regex character . represents a unique standard char only ( not EOL )
        • Then the (?:.+(\R))+ part represents a bunch of, at least, 1 complete line(s), surrounded by a non-capturing group ( (?:.......) ), each with :
          • 1 or more standard characters
          • Any kind of End of Line ( \R ), so \r\n or \n or \r, stored as the group 1 , which will be re-used in replacement
        • Finally the .+ part match a LAST non-empty line ( Thus, the case if your last section is at the very end of file, without any EOL, will be matched, too )
        • In replacement, we simply write the { character first, followed with an EOL character ( the group \1 ), followed with the whole regex ( $0 ) and, again, followed with a second EOL character and, finally, the } character
