    help thanks
    9 Posts 5 Posters 2.8k Views 3 Watching
    • DGS DGSD Offline
      DGS DGS
      please tell me how to stitch together the following lines entirely without spaces ?
      0/u/ 0.0
      0.1:5/u/ GF3ZRCM.png alt text0.00/u/
      • DGS DGSD Offline
        DGS DGS
        Подскажите пожалуйста как сшить следующие строки полностью без пробелов?
        0/u/ 0,0 0, 1:5/u/
        0,00/u/ 16
        DGS DGSD 2 Replies Last reply Reply Quote 0
        • Mark OlsonM Offline
          Mark Olson
          If all you want is to remove space within lines, just use this regex-replace:
          Search->Replace from the main menu (Ctrl+H using normal keybindings)
          Find what: \h+
          Replace with: nothing
          The regular expression \h+ matches any number of non-newline whitespace characters.
          If you need something more complicated than that, please share some detailed examples of before and after. And please remember to wrap your text in ``` like so:
          some text
          which will be rendered as:
          some text
          DGS DGSD 1 Reply Last reply Reply Quote 1
          • DGS DGSD Offline
            DGS DGS @DGS DGS
            @DGS-DGS
            added a screenshot
            • DGS DGSD Offline
              DGS DGS @Mark Olson
              @Mark-Olson
              • DGS DGSD Offline
                DGS DGS @DGS DGS
                @DGS-DGS
                it was before 0.0:56/0.0:57
                it happened after 0.0:56/0.0:56
                or like this
                how to do this?
                  Why in the world is every posting of yours a screenshot of the forum software in your browser??
                  If you’ve got a question, just type it as text, and try to have it make sense.
                    PeterJones @DGS DGS
                    @DGS-DGS ,
                    Last chance. You need to read the FAQ pages referenced, and prove that you can learn how to ask a reasonable question without spamming the same screenshot a dozen times, or you will be banned. If you create any more new accounts, they will be banned.
                    Useful References
                    • Please Read Before Posting
                    • Formatting Forum Posts
                    mkupperM 1 Reply Last reply Reply Quote 1
                    • mkupperM Offline
                      mkupper @PeterJones
                      I assume the OP’s cat or young child has has discovered the screen shot button. The list of open tabs is fascinating, are they trying to randomize their own disk or are they lost? It reminds me of “On a clear disk you can seek forever.”
                      Thank you @Mark-Olson for the \h tip. I had forgotten about that one when replying on another thread where someone used \s not realizing it also includes the end of line characters. I had not thought about it but \h is the horizontal spaces, \v is the vertical spaces, and \s is space in general.
