    Macro Sprache unverständlich / Macro language incomprehensible for me vs. Ultra Edit
    5 Posts 2 Posters 768 Views
    • Joachim MüllerJ
      Joachim Müller
      Hallo zusammen. Mein Arbeitgeber wechselt von Ultra Edit auf Notepad++. Ich habe viele Makros in UE, die ich nun umschreiben muss. Einfaches Beispiel:
      Open “M:\TOMAS\TRF0011\TRF0011P.txt”
      StartSelect
      Key END
      EndSelect
      Key DEL
      Key DEL
      Key Ctrl+END
      Key BACKSPACE
      Key BACKSPACE
      StartSelect
      Key HOME
      Key BACKSPACE
      EndSelect
      Key BACKSPACE
      Key Ctrl+HOME
      Save
      CloseFile
      Öffnen eines Textfiles, letzte beiden Zeielen löschen, erste Zeile löschen, speichern, schließen.
      Das habe ich in NP++ aufgezeichnet. Aber wenn ich das Makro ausführe, passiert einfach nichts.
      Was mache ich falsch?
      In try in english exept UE language:
      Hello everyone. My employer is switching from Ultra Edit to Notepad++. I have a lot of macros in UE that I now need to rewrite. Simple example:
      see above
      Open text file, delete the last two lines, delete the first line, save, close.
      I recorded this in NP++. But when I run the macro, nothing just happens.
      What am I doing wrong?
        Alan Kilborn @Joachim Müller
        @Joachim-Müller
        You might try this sequence after you’ve opened your file (no way to macroize opening a file into a tab):
        • Ctrl+End (move to end of file)
        • Shift+Ctrl+L (delete line of caret)
        • Backspace¹ (delete line-ending from previous line)
        • Ctrl+Home (move to beginning of file)
        • Ctrl+S (save file)
        • Ctrl+W (close file)
        ¹ : The only part that is a little strange is the Backspace, but this is needed because Shift+Ctrl+L (SCI_DELETELINE) won’t delete a “line” that has no line-ending character on its far right. In fact, depending on how you want your end-of-file to be, you may want TWO Backspace presses in place of the single one I have in the above sequence.
        Joachim MüllerJ 1 Reply Last reply Reply Quote 0
        • Joachim MüllerJ
          Joachim Müller @Alan Kilborn
          @Alan-Kilborn said in Macro Sprache unverständlich / Macro language incomprehensible for me vs. Ultra Edit:
          Ohha, you say ‘no way to macroize opening a file into a tab’. I got daily a few hundred. So I have to switch to MS Word with vba. It’s s l o w needs lots of ressources and a certifcate.
          But thank you very much for your answer.
            @Joachim-Müller
            If it is possible/desirable for you to use a scripting plugin, then a script could provide a Notepad++ based solution to your problem.
            For more info on scripting, see HERE for general automation information and HERE for further specifics about one such scripting option.
            With scripting, some pseudocode for the solution becomes:
            • iterate over a list of filename strings to act upon (for f in filename_list:)
            • open current filename (notepad.open(f))
            • get line count (N) (n = editor.getLineCount())
            • delete line N (editor.deleteLine(n-1))
            • delete line N-1 (editor.deleteLine(n-2))
            • delete line 1 (editor.deleteLine(0))
            • save (notepad.save())
            • close (notepad.close())
            Each of those (except the “iterate” at the top) translates directly (one-for-one) into available N++ script commands.
            EDIT: I’ve turned the pseudocode into pretty much a real (PythonScript) script by adding the commands off to the right in the above list of actions.
            Joachim MüllerJ 1 Reply Last reply Reply Quote 1
            • Joachim MüllerJ
              Cool! Thank you :)
              I will try :)
