    Unicode 'ÿ' , problem converting to Hex 'FF'
    36 Posts 7 Posters 3.7k Views
      Alan Kilborn @guy038
      @guy038 said in Unicode 'ÿ' , problem converting to Hex 'FF':
      if someone is interessed, I created a macro which does the translation
      I suppose the interest might be small, but why not post the macro?
      • L
        LanceMarchetti @PeterJones
        @PeterJones Thanks Peter. I will try my best to figure it out. I’m currently 55 and have zero programming background, but find computers and binary fascinating.
        Just to recap, I will try to keep this a short and as comprehensive as possible.
        Example Of The ASCII to HEX Issue I am Currently Experiencing in NP++:
        Encoding=UTF-8
        StringDataType=Image/Binary
        TotalBytes=10
        UseCase: The manual editing of the dimensions sector in the image binary allows for the creation of CTF challenges. Manual BOM manipulation allows for forced cropping and the concealment of color-data in the rest of the image. It can also be used to create pixelated patterns for unraveling. Notepad++ has met all these requirements for me so far. So I am pretty impressed at what I can get away with in various image formats.
        THIS EXAMPLE :
        Binary: GIF89a NUL NUL
        ASCII -> Hex: GIF89a20002000
        Bytes: 1-6 , Header
        Bytes: 7-10 , Dimensions
        The above ASCII to Hex conversion is 100% correct and was performed using the ASCII->Hex converter Ver4.3 by Don Ho which utilizes NppConverter.dll
        However this converter does not convert ‘ÿ’ to ‘FF’ for some reason. I therefore requested help on the Notepad++ forum and a py script was suggested to help with the ‘ÿ’ to ‘FF’ issue. The script worked successfully, but unfortunately landed up converting NUL bytes ‘00’ to spaces ‘20’.
        This is not helpful due to the fact that a space in ASCII is represented by the value ‘32’ (Hex ‘20’).
        So when it comes to image dimensions as in the GIF example above 20 00 20 00 , indicates a 32x32 pixel image.
        NOTE: Using a space ‘20’ to replace a NUL ‘00’ will still result in a 32x32 Gif image,
        HOWEVER, doing this to the dimension sector of a Jpeg will result in a 32x32px becoming a 8244x8224px image! Because the Big-Endian byte order of the 4-byte dimension block in Jpeg will translate 20202020 as 8244x8244 instead of 32x32 as in the case with GIF.
        This is why I need the script to correctly translate NUL bytes to ‘00’ and NOT ‘20’, otherwise it will create outrageous dimensions in formats like Jpeg, Webp and PNG.
        If NppConverter.dll is actually doing it right, then why can we not replicate it in Python?
        Thanks once again.
        Lance Marchetti
        L 1 Reply Last reply Reply Quote 0
        • L
          LanceMarchetti @Mark Olson
          @Mark-Olson I did not know that about VSCode, thanks, Ill look into it. Mark.
            Hello, @alan_kilborn and All,
            So, here is the contents of this macro :
                    <Macro name="Surrogates Pairs in Selection" Ctrl="no" Alt="no" Shift="no" Key="0">
                        <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?-i)\\x\{(10|[[:xdigit:]])[[:xdigit:]]{4}" />
                        <Action type="3" message="1602" wParam="0" lParam="0" sParam="$0\x1F" />
                        <Action type="3" message="1702" wParam="0" lParam="640" sParam="" />
                        <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?i)(?:(1)|(2)|(3)|(4)|(5)|(6)|(7)|(8)|(9)|(A)|(B)|(C)|(D)|(E)|(F)|(10))(?=[[:xdigit:]]{4}\x1F\})|(?:(0)|(1)|(2)|(3)|(4)|(5)|(6)|(7)|(8)|(9)|(A)|(B)|(C)|(D)|(E)|(F))(?=[[:xdigit:]]{0,3}\x1F\})" />
                        <Action type="3" message="1602" wParam="0" lParam="0" sParam="(?{1}0000)(?{2}0001)(?{3}0010)(?{4}0011)(?{5}0100)(?{6}0101)(?{7}0110)(?{8}0111)(?{9}1000)(?{10}1001)(?{11}1010)(?{12}1011)(?{13}1100)(?{14}1101)(?{15}1110)(?{16}1111)(?{17}0000)(?{18}0001)(?{19}0010)(?{20}0011)(?{21}0100)(?{22}0101)(?{23}0110)(?{24}0111)(?{25}1000)(?{26}1001)(?{27}1010)(?{28}1011)(?{29}1100)(?{30}1101)(?{31}1110)(?{32}1111)" />
                        <Action type="3" message="1601" wParam="0" lParam="0" sParam="([01]{10})([01]{10})(?=\x1F)" />
                        <Action type="3" message="1602" wParam="0" lParam="0" sParam="110110\1\x1F}\\x{110111\2" />
                        <Action type="3" message="1601" wParam="0" lParam="0" sParam="(?:(0000)|(0001)|(0010)|(0011)|(0100)|(0101)|(0110)|(0111)|(1000)|(1001)|(1010)|(1011)|(1100)|(1101)|(1110)|(1111))(?=[[:xdigit:]]*\x1F\})|\x1F" />
                        <Action type="3" message="1602" wParam="0" lParam="0" sParam="(?{1}0)(?{2}1)(?{3}2)(?{4}3)(?{5}4)(?{6}5)(?{7}6)(?{8}7)(?{9}8)(?{10}9)(?11A)(?12B)(?13C)(?14D)(?15E)(?16F)" />
                    </Macro>
            How this macro works :
            • You select a true Unicode value of a character over the BMP : \x{#####} or \x{######}, with 5 or 6 hexadecimal digits
            • You run the macro
            • You get its surrogate pair : \x{####}\x{####}
            Note that your normal selection can encompass several \x{#####} syntaxes in one go. For example, after selection of the text, below and execution of the macro :
            \x{10000} is the FIRST char over the BMP
            This SECOND char \x{14A9B} is concerned by this macro, too
            A THIRD char \x{14A9D}, very closed to the PREVIOUS one
            A FOURTH example, at the VERY END of the UNICODE range = \x{10FFFF}
            This text will be changed as :
            \x{D800}\x{DC00} is the FIRST char over the BMP
            This SECOND char \x{D812}\x{DE9B} is concerned by this macro, too
            A THIRD char \x{D812}\x{DE9D}, very closed to the PREVIOUS one
            A FOURTH example, at the VERY END of the UNICODE range = \x{DBFF}\x{DFFF}
            Now, Alan, I will concede that, for a single char, this macro is not very useful as you can, instead, just select this character over the `BMP, open the search dialog and search for all occurrences of this specific character !
            But, let’s suppose you would scan your files for those containing, let’s say, the Unicode Emoticons range of chars, which lays between the \x{1F600} and the \x{1F64F} characters. Refer to :
            http://www.unicode.org/charts/PDF/U1F600.pdf
            And which is reported, below :
            😀 \x{1F600} = \x{D83D}\x{DE00}
            😁 \x{1F601} = \x{D83D}\x{DE01}
            😂 \x{1F602} = \x{D83D}\x{DE02}
            😃 \x{1F603} = \x{D83D}\x{DE03}
            😄 \x{1F604} = \x{D83D}\x{DE04}
            😅 \x{1F605} = \x{D83D}\x{DE05}
            😆 \x{1F606} = \x{D83D}\x{DE06}
            😇 \x{1F607} = \x{D83D}\x{DE07}
            😈 \x{1F608} = \x{D83D}\x{DE08}
            😉 \x{1F609} = \x{D83D}\x{DE09}
            😊 \x{1F60A} = \x{D83D}\x{DE0A}
            😋 \x{1F60B} = \x{D83D}\x{DE0B}
            😌 \x{1F60C} = \x{D83D}\x{DE0C}
            😍 \x{1F60D} = \x{D83D}\x{DE0D}
            😎 \x{1F60E} = \x{D83D}\x{DE0E}
            😏 \x{1F60F} = \x{D83D}\x{DE0F}
            😐 \x{1F610} = \x{D83D}\x{DE10}
            😑 \x{1F611} = \x{D83D}\x{DE11}
            😒 \x{1F612} = \x{D83D}\x{DE12}
            😓 \x{1F613} = \x{D83D}\x{DE13}
            😔 \x{1F614} = \x{D83D}\x{DE14}
            😕 \x{1F615} = \x{D83D}\x{DE15}
            😖 \x{1F616} = \x{D83D}\x{DE16}
            😗 \x{1F617} = \x{D83D}\x{DE17}
            😘 \x{1F618} = \x{D83D}\x{DE18}
            😙 \x{1F619} = \x{D83D}\x{DE19}
            😚 \x{1F61A} = \x{D83D}\x{DE1A}
            😛 \x{1F61B} = \x{D83D}\x{DE1B}
            😜 \x{1F61C} = \x{D83D}\x{DE1C}
            😝 \x{1F61D} = \x{D83D}\x{DE1D}
            😞 \x{1F61E} = \x{D83D}\x{DE1E}
            😟 \x{1F61F} = \x{D83D}\x{DE1F}
            😠 \x{1F620} = \x{D83D}\x{DE20}
            😡 \x{1F621} = \x{D83D}\x{DE21}
            😢 \x{1F622} = \x{D83D}\x{DE22}
            😣 \x{1F623} = \x{D83D}\x{DE23}
            😤 \x{1F624} = \x{D83D}\x{DE24}
            😥 \x{1F625} = \x{D83D}\x{DE25}
            😦 \x{1F626} = \x{D83D}\x{DE26}
            😧 \x{1F627} = \x{D83D}\x{DE27}
            😨 \x{1F628} = \x{D83D}\x{DE28}
            😩 \x{1F629} = \x{D83D}\x{DE29}
            😪 \x{1F62A} = \x{D83D}\x{DE2A}
            😫 \x{1F62B} = \x{D83D}\x{DE2B}
            😬 \x{1F62C} = \x{D83D}\x{DE2C}
            😭 \x{1F62D} = \x{D83D}\x{DE2D}
            😮 \x{1F62E} = \x{D83D}\x{DE2E}
            😯 \x{1F62F} = \x{D83D}\x{DE2F}
            😰 \x{1F630} = \x{D83D}\x{DE30}
            😱 \x{1F631} = \x{D83D}\x{DE31}
            😲 \x{1F632} = \x{D83D}\x{DE32}
            😳 \x{1F633} = \x{D83D}\x{DE33}
            😴 \x{1F634} = \x{D83D}\x{DE34}
            😵 \x{1F635} = \x{D83D}\x{DE35}
            😶 \x{1F636} = \x{D83D}\x{DE36}
            😷 \x{1F637} = \x{D83D}\x{DE37}
            😸 \x{1F638} = \x{D83D}\x{DE38}
            😹 \x{1F639} = \x{D83D}\x{DE39}
            😺 \x{1F63A} = \x{D83D}\x{DE3A}
            😻 \x{1F63B} = \x{D83D}\x{DE3B}
            😼 \x{1F63C} = \x{D83D}\x{DE3C}
            😽 \x{1F63D} = \x{D83D}\x{DE3D}
            😾 \x{1F63E} = \x{D83D}\x{DE3E}
            😿 \x{1F63F} = \x{D83D}\x{DE3F}
            🙀 \x{1F640} = \x{D83D}\x{DE40}
            🙁 \x{1F641} = \x{D83D}\x{DE41}
            🙂 \x{1F642} = \x{D83D}\x{DE42}
            🙃 \x{1F643} = \x{D83D}\x{DE43}
            🙄 \x{1F644} = \x{D83D}\x{DE44}
            🙅 \x{1F645} = \x{D83D}\x{DE45}
            🙆 \x{1F646} = \x{D83D}\x{DE46}
            🙇 \x{1F647} = \x{D83D}\x{DE47}
            🙈 \x{1F648} = \x{D83D}\x{DE48}
            🙉 \x{1F649} = \x{D83D}\x{DE49}
            🙊 \x{1F64A} = \x{D83D}\x{DE4A}
            🙋 \x{1F64B} = \x{D83D}\x{DE4B}
            🙌 \x{1F64C} = \x{D83D}\x{DE4C}
            🙍 \x{1F64D} = \x{D83D}\x{DE4D}
            🙎 \x{1F64E} = \x{D83D}\x{DE4E}
            🙏 \x{1F64F} = \x{D83D}\x{DE4F}
            In this case, knowing the first and last surrogate values of the Emoticons range, which are \x{D83D}\x{DE00} and \x{D83D}\x{DE4F}, it’s easier to get the right regex to search for, which is \x{D83D}[\x{DE00}-\x{DE4F}] !
            And, indeed :
            • Open a new tab
            • Paste the 80 characters of the Emoticons range, with their associated value, above, in this new tab
            • Tick the Wrap around box and select the Regular expression mode
            • Enter the regex \x{D83D}[\x{DE00}-\x{DE4F}] in the Search zone
            => The 80 characters, of this Unicode range, should be marked in red-orange, all at once !
            L 1 Reply Last reply Reply Quote 3
            • L
              LanceMarchetti @guy038
              @guy038 Wow - Thanks for this macro!
              • L
                LanceMarchetti @LanceMarchetti
                @LanceMarchetti said in Unicode 'ÿ' , problem converting to Hex 'FF':
                “NOTE: Using a space ‘20’ to replace a NUL ‘00’ will still result in a 32x32 Gif image,”
                Correction: I just noticed that the GIF file format repeats the image dimension block later on in the binary, just before the image data begins.
                So I tried using Hex 20 20 20 20 in the second dimension sector as well. The result was INDEED a 8224x8224 image!
                Changing it back to 20 00 20 00 resulted in a 32x32 image.
                Just wanted to set that straight. Thanks.
                  PeterJones @LanceMarchetti
                  @LanceMarchetti ,
                  I was surprised that no one had suggested submitting a bug report to the Converter Plugin repo’s issue list regarding the ÿ portion, because even though most of your request is abusing a text editor to edit a non-text file, Notepad++'s Converter Plugin should be able to handle converting ÿ in a valid ANSI file (win1252 or ISO-8859-1 or similar codepage).
                  But when I went looking through open and closed issues, I found it’s actually already been reported multiple times – most recently, in #11… and #11 even came with a fix in PR#16, which was rejected because Don didn’t have the Steps to Reproduce.
                  Based on this conversation, I was able to come up with a minimal Steps to Reproduce, and asked Don to re-open that issue, and hopefully he will then see whether the fix #16 will work, or will come up with one that will.
                  The right answer to your full query is “Notepad++ is not a binary-file editor, so you need to accept hacky suggestions”. But ÿ should be able to be handled by the Converter plugin, so I poked the ÿ issue.
                    I didn’t look super closely at it (due to limited interest), but I’d guess this line/block is the cause of the problem:
                    https://github.com/npp-plugins/converter/blob/37d62a54a476c935f21bdd3aa37e04f3495adcb3/source/PluginDefinition.cpp#L390
                    At least it seems suspicious. 0xFF can look a lot like -1. :-)
                      @Alan-Kilborn said in Unicode 'ÿ' , problem converting to Hex 'FF':
                      Given that PR#16 changed the getChar return value, which is what that -1 is comparing against, I’d say you’re probably right.
                        @PeterJones said in Unicode 'ÿ' , problem converting to Hex 'FF':
                        I didn’t look beyond the current code.
                        • L
                          @PeterJones Thanks Peter. Appreciated. I also emailed Don last week on the ÿ issue. But have not heard back yet. So I’m grateful that you clubbed in to hopefully get it sorted.
                          I’m not a programmer as stated before, so i think you Guys are obviously on the right track with ‘-1’ because Mistral AI identified it also as such.
                          /chat.mistral.ai/chat/ec2b9a74-2da7-4bda-bfb3-e2b8681c435f/
                          I see that the provided code snippet is part of the Ascii to Hex plugin for Notepad++. Based on my analysis, the issue likely arises from the fact that the ‘ÿ’ character (Alt+0255) corresponds to the unsigned char value 255, which is interpreted as a negative value (-1) when stored in a signed char. The code then treats this negative value as an error and refuses to convert the whole block of highlighted text.
                          To fix this issue, you can modify the code to use unsigned characters instead of signed characters. Here’s an updated version of the relevant part of the code:
                          void ascii2hex(bool insertSpace, bool isMaj, size_t nbCharPerLine)
                              // ... (previous code remains unchanged)
                              unsigned char *pDestText = new unsigned char[textLen*(inc+eolNbChar)+1];
                              const char *format = "";
                              int val = static_cast<unsigned char>(selText.getChar(i));
                              if (val == -1)
                                  delete [] pDestText;
                                  return;
                              // ... (remaining code)
                          By changing the pDestText type to unsigned char and casting the result of selText.getChar(i) to unsigned char, the code should now properly handle the ‘ÿ’ character and convert it to ‘FF’ in hexadecimal.
                          rdipardoR 1 Reply Last reply Reply Quote 2
                          • rdipardoR
                            rdipardo @LanceMarchetti
                            I’m afraid this type cast will corrupt data if any character ordinal is greater than 0xFF, e.g. ġ. See, for example:
                            Fix character truncation bug that lead to ‘ġ’ styled as an operator since its low 8 bits are equal to ‘!’
                            selText.getChar already returns an int, which is 32-bits wide, so more than enough for any ASCII or Unicode ordinal.
                            The real issue is the declaration of SelectedString::_str as char *, which limits every representable “byte” to a maximum ordinal value of 0x7F. It should be the generic TCHAR * type, which becomes wchar_t * when the _UNICODE compile-time definition is set (as it always has been ever since Notepad++ became a Unicode application about 17 years ago). A wchar_t is 16 bits, which would accommodate “extended” 8-bit ASCII as well as the East Asian double-byte character sets that remain popular with some users.
