    Replace guid with guid from list randomly
    2 Posts 2 Posters 726 Views
    • Ali GaffoorA
      Ali Gaffoor
      Good day.
      would anyone know how to replace a guid with another guid from a list and do this randomly.
      example : “d0ba703e-69d4-4253-9a8c-58668bce4aea” there are multiple of this guid in the file and i would like to replace it with the following in a random pattern:
      a3ba621f-884c-4954-87e3-063014e927ff
      b56483a2-3962-4d40-adc6-3f98cb4425c4
      3b00ca11-db38-4d1d-b1e1-7ad008399919
      540e5c95-4d79-4e70-8820-574b931c4a87
      6b3fea3f-f5a4-402e-a65a-cc022d733ed4
      e757d703-7e0f-49a5-8e11-0b79f2f1f39b
      703d5a2f-3793-4e76-a7bf-d5b73231dfff
      • Mark OlsonM
        Mark Olson
        The regex gurus on this forum might come up with some kind of crazy regex-based solution to this, but this is pretty easy to solve with PythonScript.
        # requires PythonScript: https://github.com/bruderstein/PythonScript/releases
        # ref: https://community.notepad-plus-plus.org/topic/25388/replace-guid-with-guid-from-list-randomly
        import random
        import re
        from Npp import editor, notepad, MESSAGEBOXFLAGS
        def main():
            thing_to_replace = notepad.prompt('Enter the text you want to replace',
                'enter text to replace', '')
            if not thing_to_replace:
                return
            is_regex = notepad.messageBox(
                'Is the thing you want to replace a regular expression?',
                'regular expression?',
                MESSAGEBOXFLAGS.YESNO) == MESSAGEBOXFLAGS.RESULTYES
            if not is_regex:
                thing_to_replace = '(?-s)' + re.escape(thing_to_replace)
            replacements = notepad.prompt(
                'Enter a list of replacements (one per line)',
                'list of replacements', '')
            if not replacements:
                return
            replacement_list = replacements.strip().splitlines()
            def get_random_from_list(_):
                return random.choice(replacement_list)
            editor.rereplace(thing_to_replace, get_random_from_list)
        if __name__ == '__main__':
            main()
