    Proper syntax for \s (spaces) in replace expression
    17 Posts 6 Posters 6.5k Views
    • Hank KH
      Hank K
      Find:	\s{3}-\s([\S])
      Replc:	  - $1
      Needing to replace 3 spaces preceding the hyphen with 2 spaces. Searched but no joy in finding how you express \s in the Replace with: instead of using actual white spaces.
      Alan KilbornA PeterJonesP mkupperM 3 Replies Last reply Reply Quote 0
        Alan Kilborn @Hank K
        @Hank-K
        Joy: \x20
          PeterJones @Hank K
          @Hank-K ,
          I do not think that regex FIND means what you think it means.
          The document I showed has two matches:
          1. The first 6 characters of line 1
          2. The LF of the CRLF at the end of line 2 plus the CRLF on line 3 (for a total of three spaces), then the hyphen and space and t on line 4.
          I am guessing you only expected it to match one (on line 1).
          \s in the search means “any whitespace character, including spaces, tabs, and newlines”. Thus, it will find three spaces followed by a hyphen then a space then a non-whitespace (like the T in Three spaces). But it will also find three newlines followed by a hyphen followed by a whitespace followed by a non-whitespace (like the t of three newlines).
          If you want to restrict the search to just horizontal whitespace (like space or tab), then use \h instead of \s. And if you want to restrict the search to just ASCII 32 space characters, then use \x20 in the FIND just like @Alan-Kilborn suggested for the replace.
          Also, ([\S]) is completely identical to (\S) – you don’t need to wrap the \S in another character class.
          So if you want to match 3 ASCII 32 space characters, followed by a hyphen and another ASCII 32 space character, followed by something that’s not whitespace (putting that something in a capture group), then you want to FIND = \x32{3}-\x32(\S)
          Useful References
          Hank KH 1 Reply Last reply Reply Quote 0
          • Hank KH
            Hank K
            • Hank KH
              Hank K
              • Hank KH
                Hank K @PeterJones
                I’m mainly interested in what I can use in the SUBSTITUTION field. In case of nnp, the Replace with:. Instead of horizontal whitespaces ??
                Yes you were correct about ([\S]), was a copy/paste, wasn’t thinking. Didn’t dawn on me till you mention it .
                Thanks for pointing out the \h (lights got brighter here).
                https://regex101.com/r/YDgo5f/2
                Don’t like my Replace: starting or ending with horizontal whitespaces. Is there a way to encapsulate?
                • CoisesC
                  Coises @Hank K
                  @Hank-K said in Proper syntax for \s (spaces) in replace expression:
                  Find what: \h(\h\h-\h\S)
                  Replace with: $1
                  … if you really did mean to allow for any horizontal white space (in ASCII, that means tabs as well as blanks), removing the first one. If you really mean blanks, and blanks only, use \x20, as @Alan-Kilborn suggested.
                  If you only care about beginning and ending, you can use ( - $1) — parentheses are not included as literal characters in replacements unless escaped.
                  Hank KH 2 Replies Last reply Reply Quote 0
                  • Hank KH
                    Hank K @Coises
                    @Coises & Peter Jones
                    Thanks guys !!
                    Still clueless about the \x20 ?
                    • CoisesC
                      Coises @Hank K
                      https://npp-user-manual.org/docs/searching/#match-by-character-code
                      • Hank KH
                        Hank K @Coises
                        @Coises said in Proper syntax for \s (spaces) in replace expression:
                        ( - $1)
                        I previously tried the parentheses but no joy there?
                        https://regex101.com/r/gDxDVz/1
                        • CoisesC
                          Coises @Hank K
                          ( - $1)
                          All I can say is, try it in Notepad++ rather than in that website. None of the language flavors there appear to be an entirely accurate reproduction of the find and replace syntax used in Notepad++.
                          • Hank KH
                            Hank K @Coises
                            Winner, winner, chicken dinner !!
                            Works in Notepad++.
                            Lights still dim regarding \x … maybe in future it will become brighter.
                            FYI: Will do all future testing directly in Notepad++
                            Thanks for hangin with me through my regex growth … lol
                            • CoisesC
                              Coises @Hank K
                              \x just means “the next two characters are going to be two hexadecimal digits that represent the bit pattern of the character I want.”
                              Hexadecimal 20 is the bit pattern for an ASCII space. See: https://en.wikipedia.org/wiki/ASCII#Character_set
                                ( - $1)
                                Joy: To use parentheses in Replace with: field, you must escape them, e.g. \( and \),
                                • mkupperM
                                  mkupper @Hank K
                                  Replc:	  - $1
                                  Unfortunately there are only two ways to put a space in the replace part of a regular expression. Those are an actual space like what you used or the sequence \x20. Shortcuts such as \s and \x20{2} don’t work in the replacement part.
                                  Now, there something that could work for you which is
                                  Find: \x20(?=\x20\x20-)
                                  Replace: nothing
                                  In the find part we are looking for a single space followed by a lookahead that has two spaces and the hyphen.
                                  The replacement part only affects the single leading space and won’t replace the pattern that is inside the lookahead.
                                  Do a search for \x20(?=\x20\x20-). You will see that the first space becomes selected and the cursor is at the end of it. The search does not seem to find the following two spaces and the hyphen but you will discover that it is including them as part of the overall match. You can experiment with both this expression and with the your to get a better understanding of how lookahead works.
                                  \x20 is the internal code for a space in both ASCII and Unicode. You will often see \x20 in regular expressions as it’s easy to miss a space, particularly at the very beginning or end of the expression.
                                  Do a search for \x20 in Notepad++ and you’ll see that it finds spaces.
                                  Don’t use \s unless you also intend to find tabs plus a rather long list of other characters such as form feeds. \s tends to match anything you can’t see…
                                    Hello, @hank-k, @alan-kilborn, @peterjones, @coises and All,
                                    And here is my solution :
                                    SEARCH \x20{3}(?=-)
                                    REPLACE \x20\x20
                                    OR
                                    SEARCH \x20{3}(?=-)
                                    REPLACE ( )
                                    There are two space chars between the parentheses !
                                      Alan Kilborn @guy038
                                      @guy038 said in Proper syntax for \s (spaces) in replace expression:
                                      REPLACE ( )
                                      Tricky. :-)
                                      The parens are only used because the OP was “uncomfortable” with whitespace he couldn’t really see in the Replace with box.
