    T-SQL highlighting problem: backslash is not an escape character here
    3 Posts 3 Posters 576 Views
    • PeterAdamP
      PeterAdam
      The backslash at the end of the 9th line in the string breaks highlighting:
      Removing the backslash the highlighting gets good, but the script turns to be wrong:
      Can it be fixed? Should I try to edit the langs.xml file?
      Best regards,
      Peter
      Notepad++ v8.5.8 (64-bit)
      Build time : Oct 15 2023 - 21:43:56
      Command Line :
      OS Version : 22H2
      OS Build : 19045.3570
      Current ANSI codepage : 1250
      Plugins :
      AutoCodepage (1.2.6)
      FWDataViz (2.6.2)
      JsonTools (5.6)
      MarkdownViewerPlusPlus (0.8.2)
      mimeTools (2.9)
      NppConverter (4.5)
      nppcrypt (1.0.1.6)
      RestApiToText (1.4.0.1)
      urlPlugin (1.2)
      XMLTools (3.1.1.13)
      _CustomizeToolbar (5.3)
      Alan KilbornA mpheathM 2 Replies Last reply Reply Quote 0
        Alan Kilborn @PeterAdam
        @PeterAdam
        • mpheathM
          mpheath @PeterAdam
          @PeterAdam
          The styling looks like the SQL lexer (for SQLite3,…) which is not the correct lexer for T-SQL. The @variables are not colored as they should. Problems with escapes…
          From the Language menu, select the Microsoft Transact-SQL lexer and you may see
          The langs.xml file in %AppData%\Notepad++ may need updating if Microsoft Transact-SQL is not in the menu. Compare it with langs.model.xml that is in %ProgramFiles%\Notepad++ .
