    Help with search and replace code
    11 Posts 5 Posters 651 Views
    • Jessica BrunoJ
      Jessica Bruno
      Hi,
      I’m modding some game files and hoping to do this in bulk as there are hundreds to do! The format of the files is as follows:
      price: 26200
      unlock: 0
      How would I set this to change the ‘price’ (which could be any number from 1 to infinity) to 1, and the ‘unlock’ (which could be anything from 0 to infinity) to 0?
      Thanks
        Alan Kilborn @Jessica Bruno
        @Jessica-Bruno
        If you set the find Search mode to Regular expression, you can search for variable numbers with \d+; example: price: \d+
          Hello, @jessica-bruno, @alan-kilborn and All,
          To complete the @alan-kilborn’s answer, I would say
          SEARCH (?-i)(?=price: )\d+
          REPLACE 1
          and :
          SEARCH (?-i)(?=unlock: )\d+
          REPLACE 0
          And, of course, tick the Regular expression search mode
          Note : (?-i), at beginning of the regex, means that this regex is sensitive to case ( so NON-insensitive )
          Alan KilbornA Paul WormerP 2 Replies Last reply Reply Quote 0
            Alan Kilborn @guy038
            @guy038
            I think the virtue of my answer is that the OP could possibly remember it as a technique, whereas your answer likely results in “mind blown”, won’t remember.
            • Paul WormerP
              Paul Wormer @guy038
              @guy038 Don’t you mean (?-i)(?<=price: )\d+ ?
                Hi, @jessica-bruno, @paul-wormer, @alan-kilborn and All,
                Oh… yes ! I was wrong and, in addition to Alan remark, my first post gave very poor information !
                So, the exact search regexes are, of course :
                • SEARCH (?-i)(?<=price: )\d+
                and
                • SEARCH (?-i)(?<=unlock: )\d+
                Jessica BrunoJ 1 Reply Last reply Reply Quote 3
                • Jessica BrunoJ
                  Jessica Bruno @guy038
                  @guy038 said in Help with search and replace code:
                  Thank you very much, this worked perfectly.
                  @Alan-Kilborn said in Help with search and replace code:
                  @guy038
                  I thank you for your belief that I could be even begin to understand any of the code involved with this! No chance!!
                    @Jessica-Bruno said in Help with search and replace code:
                    Maybe if I’d have pointed out that in \d+ the d stands for “digit”?
                    The \ before it makes the d “special” (otherwise how would the program know you wanted something other than a real d?).
                    The + after it means “one or more”.
                    So put it all together and \d+ means “one or more digits”.
                    See, not that hard, and possibly memorable?
                      Hello, @jessica-bruno, @paul-wormer, @alan-kilborn and All,
                      As @alan-kilborn, here are some more explanations on the regexes :
                      • They both search for, at least, one character, considered as a digit, but ONLY IF preceded by the string price: or the string unlock:, with this exact case, and followed by a space character
                      • The four syntaxes (?=aaaaa) and (?!bbbbb), as well as (?<=ccccc) and (?<!ddddd), are called look-arounds which allow you to search for any expression :
                        • ONLY IF followed by the aaaaa string
                        • ONLY IF NOT followed by the bbbbb string
                        • ONLY IF preceded by the ccccc string
                        • ONLY IF NOT preceded by the ddddd string
                      • Note that the strings aaaaa, bbbbb, ccccc and ddddd are NEVER part of the expression to search for, but must be true in order to produce a valid match of the whole regex expression !
                      mkupperM 1 Reply Last reply Reply Quote 2
                      • mkupperM
                        mkupper @guy038
                        @guy038 The not versions always seem deadly. For example (?!bbbbb) also matches between each of the letters within bbbbb and (?<!ddddd) also matches between the letters within ddddd.
                          Hello, @jessica-bruno, @mkupper and All,
                          @mkupper, you’re right but these negative look-arounds are not intended to be used on their own but rather with a part outside the look-around(s !
                          Refer to the two tables below.
                          • Copy the text of the first column in a new tab
                          • Use the Mark dialog to get the text matched by each of these 9 regexes, in a red/orange color ( tick the Purge for each search option ) !
                          The results should be as below :
                          |                     |         12345          |    12345(?=aaaaa)    |    12345(?!bbbbb)    |    (?<=ccccc)12345    |    (?<!ddddd)12345    |
                          |   12345aaaaa        |           X            |          x           |          X           |                       |           X           |
                          |   12345bbbbb        |           X            |                      |                      |                       |           X           |
                          |   12345zzzzz        |           X            |                      |          X           |                       |           X           |
                          |   ccccc12345        |           X            |                      |          X           |           X           |           X           |
                          |   ddddd12345        |           X            |                      |          X           |                       |                       |
                          |   zzzzz12345        |           X            |                      |          X           |                       |           X           |
                          |   ccccc12345aaaaa   |           X            |          X           |          X           |           X           |           X           |
                          |   ccccc12345bbbbb   |           X            |                      |                      |           X           |           X           |
                          |   ccccc12345kkkkk   |           X            |                      |          X           |           X           |           X           |
                          |   ddddd12345aaaaa   |           X            |          X           |          X           |                       |                       |
                          |   ddddd12345bbbbb   |           X            |                      |                      |                       |                       |
                          |   ddddd12345zzzzz   |           X            |                      |          X           |                       |                       |
                          |   zzzzz12345aaaaa   |           X            |          X           |          X           |                       |           X           |
                          |   zzzzz12345bbbbb   |           X            |                      |                      |                       |           X           |
                          |   zzzzz12345zzzzz   |           X            |                      |          X           |                       |           X           |
                          |                     |   (?<=ccccc)12345(?=aaaaa)   |    (?<=ccccc)12345(?!bbbbb)    |    (?<!ddddd)12345(?=aaaaa)    |    (?<!ddddd)12345(?!bbbbb)    |
                          |   12345aaaaa        |                              |                                |               X                |               X                |
                          |   12345bbbbb        |                              |                                |                                |                                |
                          |   12345zzzzz        |                              |                                |                                |               X                |
                          |   ccccc12345        |                              |               X                |                                |               X                |
                          |   ddddd12345        |                              |                                |                                |                                |
                          |   zzzzz12345        |                              |                                |                                |               X                |
                          |   ccccc12345bbbbb   |                              |                                |                                |                                |
                          |   ccccc12345kkkkk   |                              |               X                |                                |               X                |
                          |   ddddd12345aaaaa   |                              |                                |                                |                                |
                          |   ddddd12345bbbbb   |                              |                                |                                |                                |
                          |   ddddd12345zzzzz   |                              |                                |                                |                                |
                          |   zzzzz12345aaaaa   |                              |                                |               X                |               X                |
                          |   zzzzz12345bbbbb   |                              |                                |                                |                                |
                          |   zzzzz12345zzzzz   |                              |                                |                                |               X                |
