    Need Help to replace a text by finding other text as keyword
    4 Posts 4 Posters 305 Views
    • Hendrick TheaH
      Hendrick Thea
      i want to find specific word but using other text as keyword. is it possible?
      For Ex:
      -Name : David
      Sex : Male
      -Name : Sara
      Sex : Female
      -Name : Felicia
      Sex : Female
      -Name : Erick
      Sex : Male
      i want to replace all Age to 30 by finding keyword male.
      thanks
      Paul WormerP 1 Reply Last reply Reply Quote 0
      • Paul WormerP
        Paul Wormer @Hendrick Thea
        @Hendrick-Thea
        Find:
        (?-s)(Age\h+:\h+)(\d{1,2})(.*\RSex\h+:\h+Male)
        Replace:
        ${1}30${3}
        Assumption: no male is older than 99 years.
          Hello, @hendrick-thea, @paul-wormer and All,
          An alternate solution, which allow leading indentation :
          So, from this INPUT tet :
          -Name : David
          Sex : Male
          -Name : Sara
          Sex : Female
          -Name : Felicia
          Sex : Female
              -Name : Erick
              Sex : Male
          The following regex S/R :
          SEARCH (?<=Age : )\d+(?=.*\R\h*Sex : Male)
          REPLACE 30
          Would produce this OUTPUT text :
          -Name : David
          Sex : Male
          -Name : Sara
          Sex : Female
          -Name : Felicia
          Sex : Female
              -Name : Erick
              Sex : Male
          • Mark OlsonM
            Mark Olson
            All of the above solutions are good, but they are not necessarily very robust to reformatting of the document, which appears to be YAML.
            Normally this is where I’d recommend a plugin or a PythonScript solution for working with YAML, but I don’t know of any plugins, and Python’s YAML package is not in the Python standard library, so using PythonScript for YAML isn’t a great option.
            Having said that, my general suggestion for performing these kinds of manipulations on YAML documents is to learn a scripting language (I recommend Python) and using that to write normal Python scripts. If you end up going that route, this forum will cease to be a useful resource and StackOverflow becomes one of your best friends.
