    Issues with Vertical Edge Setting + User Defined Language
    2 Posts 1 Posters 263 Views
      A Former User
      Hello all,
      I’m not the best with Notepad++ and don’t use it for coding, so hopefully I don’t sound too inept. I’m using it for a writing project where the line maximum needs to be 78 characters.
      I tried using the Vertical Edge Settings option under Preferences > Margins/Border/Edge, but setting it to 78 produces:
      Imgur Pic, 78 VES
      Whereas setting it to 97 produces the intended result:
      Imgur Pic, 97 VES
      It might be important to note that I do have a user defined language for this writing project that just highlights the specific syntax used. I didn’t write the language and received it from someone else.
      However, when I switch from the user defined language to markdown (preinstalled), having the Vertical Edge Setting to 78 works as intended:
      Imgur Pic, w/ Markdown Enabled
      ? 1 Reply Last reply Reply Quote 0
        A Former User @A Former User
        Edit: I fixed this, in case anyone has any issues with it later. I just had to uncheck global font size.
