    CS-SCRIPT problem after rebuilding machine.
    cs-script
    2 Posts 2 Posters 634 Views
    • Pat Sinclair 0P
      Pat Sinclair 0
      Greetings All:
      Recently had to rebuild my machine, working on restoring NPP and CS-SCRIPT code that I use for automation.
      Currently getting the error:
      error CS0246: The type or namespace name ‘NppScripts’ could not be found (are you missing a using directive or an assembly reference?)
      At the top of my scripts I have the following:
      //css_ref C:\Program Files\Notepad++\plugins\NppScripts\NppScripts.dll
      //css_ref C:\Program Files\Notepad++\plugins\NppScripts\NppScripts\NppScripts.asm.dll
      using NppScripts
      I tried changing it to the following as the old plugin was updated to Version 2.0.3.0:
      //css_ref C:\Program Files\Notepad++\plugins\CSScriptNPP\CSScripts.dll
      //css_ref C:\Program Files\Notepad++\plugins\CSScriptNpp\CSScriptNpp\CSScripts.asm.dll
      using CSScripts;
      Now it just states unable to find CSScripts…
      Can someone please help, I am not able to figure out how to solve this, I use things like Editor.GetCurrentFilePath() which required the NppScripts using.
      Thanks in advance for any and all feedback.
      Regards,
      Pat
      • Mark OlsonM
        Mark Olson @Pat Sinclair 0
        @Pat-Sinclair-0
        Go to repo with plugin issue if you haven’t already.
        if I had a penny for every time I said something like this to somebody posting about a plugin issue on the community forum… (don’t worry OP, I’m not mad at you, just amused at how often I say something to this effect)
