    How to Add Run Option in Notepad++ for Launch in Edge
    launchedgerun-menulaunch in edge
    7 Posts 4 Posters 2.4k Views 2 Watching
    • Theo FondseT Offline
      Theo Fondse
      To add a Run menu option in Notepad++ for “Launch in Edge”, use the below steps:
      1. Backup your AppData\Roaming\Notepad++\shortcuts.xml file.
      2. Edit your AppData\Roaming\Notepad++\shortcuts.xml file.
      3. Under the UserDefinedCommands section add the below line:
      <Command name=“Launch in Edge” Ctrl=“no” Alt=“no” Shift=“no” Key=“0”>msedge "$(FULL_CURRENT_PATH)"</Command>*
      1. Save the file.
      2. Restart Notepad++
      • Alan KilbornA Online
        Alan Kilborn @Theo Fondse
        @Theo-Fondse
        Simpler way #1:
        Theo FondseT 1 Reply Last reply Reply Quote 5
          Simpler way #2:
            Theo Fondse @Alan Kilborn
            @Alan-Kilborn Thanks!
              PeterJones @Theo Fondse
              @Theo-Fondse ,
              Please note that @Alan-Kilborn’s second method is described in the User Manual already, and is effectively the GUI-way of doing the laborious manual-shortcuts.xml-editing that you described.
              • https://npp-user-manual.org/docs/run-menu/#additional-browser-options
                Theo Fondse @PeterJones
                @PeterJones Thanks! Good to know!
                • Zee jeeZ Offline
                  Zee jee
