    How to find and copy all numbers which start with same country code in notepad++ ??? Please HELP!
    search
    5 Posts 3 Posters 2.4k Views 1 Watching
    • Bonnie StevensB Offline
      Bonnie Stevens
      I need to find all numbers which start with same country code from all my list. How I can do this?
      • T Offline
        Terry R @Bonnie Stevens
        @Bonnie-Stevens
        Well if you expect a good answer from what little you have provided you are expecting too much.
        How about reading a FAQ post here which shows you how to insert relevant examples. You will also need to expand more on such things as the country code you seek. We need to see how the list is formatted as that has a very large input to how the solution is created.
          Bonnie Stevens
          Ijust want to know how I can make search by the first digits from the whole list. Now if I write for example “44” I see all rerults. My required numbers which start with “44” and all other info like post codes with “44” house numbers with “44” , etc,…
          T Lycan ThropeL 2 Replies Last reply Reply Quote 0
          • T Offline
            @Bonnie-Stevens said in How to find and copy all numbers which start with same country code in notepad++ ??? Please HELP!:
            Do I need to repeat again my previous post. How do you expect us to provide the answer when we have no idea on how the list is formatted. All you have added is the above statement “…by the first digits…”. I’ve no idea if that means the first characters on each line, or the first after the second comma on the line or perhaps the first after the ( which appears after the first address line.
            • Lycan ThropeL Offline
              Lycan Thrope @Bonnie Stevens
              @Bonnie-Stevens ,
              The people here are not mind readers, regardless of your native language. If you refuse to read the documents that you have been given links to, to describe the problem you are having, then like the old computer programming adage, “Garbage in, Garbage out”, is all you will get.
              If you won’t put the work in to describe the issue, you can not be helped. Read links that Terry gave you.
