nppPluginList npp-compatible-versions and old-versions-compatibility parameters
I received an issue from a github user for the latest version of my CSV Lint plugin
but I wasn’t able to reproduce this. The debug info they posted says “Notepad++ v8.4.6” which is an older Notepad++ version, so I started looking into older versions and the compatibility with the plug-in.I ended up doing some extensive testing, installing several different Notepad++ versions, and older versions of the plugin. I haven’t tried every single combination, but see the result below.
Wherever there is a text like “ok” etc. I have explicitly confirmed it, so the texts mean:
ok = no issues LEXER! = crashes due to lexer v5 issues, known bug not comp = Notepad++ flags this plugin version as "not compatible" and won't use the dll ok DM issue = (one time) in Dark Mode some funky purple/orange dialogs but otherwise okLooking at the compatibility I found, obviously any version v0.4.5 and older should not run on the newer Notepad++ versions. But I was a bit surprised that the latest version of CSV Lint also ran on the oldest Notepad++ v8.2 that I tested, it didn’t crash and worked just fine.
Starting with version v0.4.5.2 of CSV Lint it was submitted to nppPluginList with two extra parameters, see here
"npp-compatible-versions": "[8.4,]", "old-versions-compatibility": "[,0.4.5.1][,8.3.3]",If I understand correctly this means Notepad++ v8.4 or newer should use the latest plugin, and Notepad++ v8.3.3 and older should use 0.4.5.1 or older.
My question is, looking at this compatibility chart, is this still correct? I mean give that Don Ho himself initially set them I’m hesitant to change them, but couldn’t they be changed to
[8.2,]for the first one, and[,0.4.6.4][,8.3.3]for the second? Or are the two versions not supposed to overlap, so to speak, so the Npp version in the “npp-compatible” should always be higher than the “old-versions” one? -
B Bas de Reuver referenced this topic on
@Bas-de-Reuver
Nice detective work!I had something similar happen with JsonTools. My older versions of that plugin were only compatible with 8.4.1+, and then I found a bug that made it compatible back as far as I bothered to test (7.3.3).
So here’s what I currently have in NppPluginList for JsonTools:
"npp-compatible-versions": "[7.3.3,]", "old-versions-compatibility": "[,4.10.0][8.4.1,]"In short, the only rule is that these values should accurately reflect the compatibility of current versions and older versions.
So yeah, probably for CsvLint you would want
"npp-compatible-versions": "[8.2,]", "old-versions-compatibility": "[,0.4.5.1][8.2,8.3.3]",Unless you can verify that the older versions of your plugin work on older NPP than 8.2, I would err on the side of not saying that it does.
My strategy (admittedly not the most thorough) was to not bother trying to test JsonTools on every single NPP release since 7.3.3. I just picked 7.3.3, 7.8.9, and 1-3 bugfix releases from every minor release since 8.3.
@Mark-Olson said in nppPluginList npp-compatible-versions and old-versions-compatibility parameters:
Thanks, it felt a bit like playing minesweeper 😆
If I understand correctly, the two parameters were added in Notepad++ v8.4.4 and they are baked into the Notepad binary file. So that means older Npp versions like 7.3.3 don’t even look at these parameters I assume?
@Bas-de-Reuver
No, the plugin list is actually a separate plugin, atplugins/config/nppPluginList.dll.But now that you mention it, the plugin manager can’t even be installed on 7.3.3 (just tried it now), so as far as the plugin manager is concerned it’s not super important to test your plugin that far back.
@Mark-Olson said,
Please be very precise when talking about Plugins Admin, especially when talking about versions going back that far.
In Notepad++ v7.5.9 and earlier, there was a plugin called “Plugin Manager” which was used for managing plugins (it shipped with Notepad++ through v7.4.2, even though it was maintained by someone else; but in v7.5, it stopped shipping with Notepad++ due to advertisements added to “Plugin Manager”). That plugin is incompatible with Notepad++ v7.6 and newer.
In Notepad++ v7.6, Notepad++ shipped with a new built-in Plugins Admin tool (though it wasn’t stable until v7.6.3). The list of plugins for the Plugins Admin tool is provided by the DLL called
plugins/config/nppPluginList.dll, but it is not itself a plugin (not all DLLs are “Plugins”). That DLL does nothing before v7.6, because nothing inside Notepad++ was looking for that DLL before then (and since it’s not a plugin, it doesn’t get auto-recognized like real plugins do).
Thus, when you talk about “plugin manager”, but are talking about the
nppPluginList.dll, you should really be calling it Plugins Admin, which is the name that shows up in the Plugins menu and the Plugins Admin dialog box.So the “earliest” you might want to test compatibility for setting in the nppPluginList repo is Notepad++ v7.6.3
@Bas-de-Reuver said in nppPluginList npp-compatible-versions and old-versions-compatibility parameters:
Not surprising if you consider that N++ doesn’t actually know what lexer functions it’s looking for. It calls them through function pointers, which are nothing but pointers to
void. All that any C++ app can do is dereference them and hope there’s a real function at the other end.As long as current versions of your plugin export
GetLexerCount,GetLexerNameand the (now obsolete)GetLexerFactoryandGetLexerStatusText, that’s enough to pass in pre-8.4 N++ versions. One of my own plugins was backported all the way to v7.7 by exporting a stub ofGetLexerFactorythat simply returns0.
