    problem with this regex: \b.{1,6}\b
    5 Posts 4 Posters 306 Views
    • Bahaa0013B
      Bahaa0013
      I made a simple regex “\b.{1,6}\b” that matches every word contains less than 7 charecters,
      And yes it works, But the problem that it’s matching this type of words: “ab!cdefghi”, while it contains 10 charecters… maybe because it contains “!” symbol.
      so is there any way to make a regex that don’t match words contains +6 charecters even it contains a symbol like “!”
      • Mark OlsonM
        Mark Olson @Bahaa0013
        @Bahaa0013
        (?<!\S)\S{1,6}(?!\S)
        abdc!
        ~~~NO
        #R%$%$%#
        abcdefg
        My regex will mark only first six lines, not last two.
        Note that I chose the negative assertions “not not a whitespace before or after” ((?<!\S) and (?!\S)) because that assertion matches at the beginning and end of the file, and the alternative “must be a whitespace” ((?<=\s) and (?=\s)) do not.
        Alan KilbornA Bahaa0013B 2 Replies Last reply Reply Quote 4
          Alan Kilborn @Mark Olson
          @Mark-Olson
          Nice point about matching at start/end of file.
            Hello, @mark-olson,
            Indeed, I would not have thought of that. As always, it is the borderline cases that need to be studied !
            • Bahaa0013B
              Bahaa0013 @Mark Olson
              @Mark-Olson
              Thank you very much, it worked very well…
              Also thanks to everyone who tried to help.
