    Little Dialog-wrapper for PythonScript
    74 Posts 8 Posters 44.8k Views
      Michael Vincent @Alan Kilborn
      @Alan-Kilborn said in Little Dialog-wrapper for PythonScript:
      For others that might be interested, here’s a full version of Michael Vincent’s dictionary script with rdipardo’s changes:
      @rdipardo
      Sorry I haven’t been around in a while, just getting back now. Thank you for the updates; I’ve converted my dictionary and translator scripts to use the more portable method as urllib does indeed come with PythonScript. And yes, I have the PythonScript plugin set to “see” my installed Python3 - which had the requests module installed.
      Happy we’re getting some traction out of @Ekopalypse 's Dialog-wrapper - truly ingenious and adds lots of menu / dialog functionality to PythonScripts.
        Ekopalypse @Alan Kilborn
        Probably the code in test_different_ways_to_create_dialogs.py in the test folder needs the same change?
        Yes, correct and done, thanks for pointing it out.
        What I like to do if I have code that runs two ways is …
        They are tests, actually not meant as examples, my point was rather,
        that the dialogs generated in each case, or more precisely, the resulting ByteArrays are compared,
        but I understand what you mean. If I have a little more time sometime in the future,
        I will tackle that.
        Right now I’m using my meager free time to get the NppLspClient plugin into beta status, and then I wanted to rewrite the NppDebugger because my employer won’t allow me to release the existing plugin.
        (The downside, if you develop something during working hours, suddenly it doesn’t belong to you anymore) :-(
        (The advantage is that I can learn and use a new language, probably Rust or Zig, but I don’t know for sure yet) :-)
          Alan Kilborn @Ekopalypse
          @Ekopalypse said in Little Dialog-wrapper for PythonScript:
          Without a specific set of examples, the tests become the examples. :-)
          Actually, I think Michael led me down the road of the tests being examples…I didn’t think too hard about it at first.
          It is reasonable that it doesn’t belong to you, but it seems unreasonable that your employer won’t release it. It would be understandable if your employer was a developer of rocket fuel and your plugin calculated optimized rocket fuel ingredient proportions… But as a general purpose tool that won’t give a competitor some sort of edge, why not share it? Sigh.
            Alan Kilborn @Michael Vincent
            @Michael-Vincent
            Not to get too far off-track with this thread, as it’s meant to highlight the Little Dialog-wrapper, but I noticed that in your “dictionary” script, if the selected “word” to look up isn’t spelled correctly (such that it isn’t a real word), unhandled exceptions occur (just check the PS console window).
            Before I noticed this I got to thinking about the utility of dictionary programs. They’re fine if you know how the word is spelled and you want other info about it. But if you don’t know the spelling, it is hard to get you where you need to go.
            Perhaps the script, if it doesn’t get an exact match, it should do a web search on the word of questionable spelling, e.g. N++'s Edit > On selection > Search on Internet. From that output, the user could correct the spelling input to the script and get further info about the word.
              Indeed. Quick fix:
                  def _on_lookup(self):
                      """Lookup the word."""
                      self._initialize()
                      text_encoded = urllib.parse.quote(self.word.getText())
                      headers = {"User-Agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.77 Safari/537.36"}
                      try:
                          r = requests.urlopen(requests.Request(url=f"http://api.dictionaryapi.dev/api/v2/entries/en/{text_encoded}", headers=headers))
                      except urllib.error.HTTPError:
                          notepad.messageBox('No definitions found.  Perhaps misspelled?', 'Error')
                          self.terminate()
                          return
                      if r.status != 200:
                          self.terminate()
                          return
                So I was attempting to do something “real” with the Little Dialog Wrapper, and it fell a bit short in capability in a couple of areas.
                I’m not complaining, mind you, I just thought I’d share my findings. And, of course, I could be doing something wrong that is indeed quite simple to do correctly.
                I wanted my dialog to start up with a checkbox in the checked state and I found no easy way to do it. I tried the obvious:
                self.my_checkbox.setCheckState(BST.CHECKED)
                right before the call to self.show(), but this did not achieve the goal.
                The workaround that I came up with that did work was:
                import threading
                threading.Timer(0.25, lambda : self.my_checkbox.setCheckState(BST.CHECKED)).start()
                I also found no obvious function (meaning part of the WinDialog hierarchy) to call to disable a control. With a little ctypes help I worked around by doing:
                from ctypes import WinDLL
                user32 = WinDLL('user32')
                user32.EnableWindow(self.my_checkbox.hwnd, False)
                And again, this didn’t work if I wanted to start up with a control disabled. So I resorted to:
                threading.Timer(0.25, lambda : user32.EnableWindow(self.my_checkbox.hwnd, False)).start()
                for that.
                Michael VincentM EkopalypseE 3 Replies Last reply Reply Quote 0
                  The way I got it to work was:
                  class Returns(object):
                      def __init__(self, U=None, I=False, X=False):
                          self.user_input = U
                          self.IGNORECASE = I
                          self.REGEX      = X
                          self._RESET      = False
                          self._OK         = False
                  class FilerLinesEditDlg(Dialog):
                      def __init__(self, ret=Returns()):
                          super().__init__(            title=TITLE                 , center = True,      size=(250, 75) )
                          self.ok     = DefaultButton( title='&OK'                 , position=(135, 55), size=(50, 11)  )
                          self.label  = Label(         title='Filter for:'         , position=(10, 12),  size=(30, 11)  )
                          self.edit   = TextBox(                                     position=(45, 10),  size=(195, 14) )
                          self.case   = CheckBoxButton(title='Case &Sensitive'     , position=(45, 30),  size=(80, 14)  )
                          self.regex  = CheckBoxButton(title='Regular E&xpression' , position=(145, 30), size=(80, 14)  )
                          self.cancel = Button(        title='&Cancel'             , position=(190, 55), size=(50, 11)  )
                          self.reset  = Button(        title='&Reset'              , position=(45, 55),  size=(50, 11)  )
                          self.ret = ret
                          self.onIdOk         = self.on_ok
                          self.ok.onClick     = self.on_ok
                          self.cancel.onClick = self.on_cancel
                          self.reset.onClick  = self.on_reset
                          self.case.onClick   = self.on_case
                          self.regex.onClick  = self.on_regex
                          self.show()
                      def initialize(self):
                          self.edit.setText(self.ret.user_input)
                          SendMessage(self.case.hwnd,  BM.SETCHECK, self.ret.IGNORECASE, 0)
                          SendMessage(self.regex.hwnd, BM.SETCHECK, self.ret.REGEX, 0)
                  This is the “relevant” parts of a larger script - my version of your filter lines editing actually.
                  I create an object to store the values so then I can return them and save them in the global PythonScript object so next time I call it I can set the checkboxes appropriately. The initialize() function does the checkbox-ing.
                    @Michael-Vincent is correct, to quote from the Dialog help
                     |  initialize(self)
                     |      Initializes the dialog and its controls at runtime.
                     |      This method is intended to be overridden by a concrete class.
                     |      It is executed after all controls have been created but before the dialog is displayed.
                     |      Concrete implementations should provide custom logic to set up initial values, states, and configurations of the controls.
                    It might be worth adding function(s) to enable or disable controls, yes. PRs are welcome :-)
                      simple example
                      from WinDialog import Dialog, CheckBoxButton
                      from WinDialog.controls.button import BST
                      class Example(Dialog):
                          def __init__(self):
                              super().__init__(size=(100, 100))
                              self.btn1 = CheckBoxButton(title='Click me', position=(35, 40), size=(50, 14))
                              self.show()
                              self.btn1.setCheckState(BST.CHECKED)
                      Example()
                        @Michael-Vincent said in Little Dialog-wrapper for PythonScript:
                        This is interesting. How do you kick off the saving of the current values? Meaning, if user presses Esc to close the dialog, or presses the red X in the title bar of the dialog, are you able to capture this and save your current control values? Maybe in your script you wouldn’t want to save in these circumstances, but OTOH maybe you would…
                          You have an initial state when you start the dialog and from there I would use the control events to get the values you need. Something like
                              def __init__(self):
                                  self.counter = 0
                                  self.btn1.onClick = self.on_click
                                  self.show()
                              def on_click(self):
                                  self.counter += 1
                          e = example()
                          print(e.counter)
                          Alan KilbornA 2 Replies Last reply Reply Quote 1
                            … use the control events to get the values you need.
                            Sure, but that’s the obvious case.
                            That’s why I specifically asked MV “…if user presses Esc to close the dialog, or presses the red X in the title bar of the dialog…”
                            As far as I can tell, and yes I’ve read some of the docs now :-), these aren’t capturable events?
                              @Ekopalypse
                              BTW, I sort of missed this at first from the github page:
                              help(WinDialog)
                              I guess I’m just not used to documentation being provided in only this way, at least not any more. It’s totally fine, though, just maybe not super obvious for a newbie (would there be any newbies wanting to experiment with LDW??).
                              So maybe I’ll offer this on the off-chance that a newbie is reading; this is what I did to make it easier to refer to (note: nothing rocket sciencey here…):
                              • go to PythonScript console window area, right-click, and choose Clear from the popup menu
                              • at the >>> prompt, type import WinDialog and press return
                              • type help(WinDialog) and press return
                              • right-click again and choose Select All and then press Ctrl+c
                              • create a new tab in Notepad++ and paste there
                              • save the tab for later reference
                                They get saved. That’s why I use a return class object that’s part of the main script. So in the example I provided, I want to remember the setting for “ignore case” and “regex” so the checkboxes have an onClick event that toggles the boolean value stored in the return class.
                                    def on_case(self):
                                        self.ret.IGNORECASE = not self.ret.IGNORECASE
                                    def on_regex(self):
                                        self.ret.REGEX = not self.ret.REGEX
                                That happens whenever the users clicks the checkbox. So if they later just press ‘Esc’ or red ‘X’, the value has already been stored and then next time it launches, it is checked (or unchecked) appropriately in the initialize().
                                  They get saved.
                                  It’s not what I was truly getting at, but I understand how you’ve made it work. Thanks.
                                    I don’t seem to understand your use case.
                                    If I want to know if a user either pressed ESC or clicked close_X to simply exit the dialog without anything being triggered by the dialog, then I would start the dialog with a variable has_been_cancelled=True and override it with the click event of the “normal” exit_dialog_button.
                                    If that’s not what you’re looking for, maybe you can specify a simple scenario of what should be handled?
                                      @Ekopalypse
                                      I meant an optional user (the programmer-user) function that gets called when the dialog is closing, by whatever means. Then there’s a chance to do things at that point, much like, but the opposite of initialize(). Maybe I will think about working on that kind of thing, along with enabling/disabling of controls.
                                        My very first script using this wrapper is HERE !!
                                        I think it turned out pretty well and puts this wrapper through its paces. :-)
                                        About the only annoying thing is that the dialog is modal, i.e., one can’t switch between it and the Notepad++ editor window. This is annoying because one can do this with Notepad++'s Find window, and thus one gets used to this behavior.
                                        Maybe another suggested extension is that if the dialog (is made modeless) and loses input focus, the script ends and the dialog disappears. Sure, the user would have to restart the script (via assigned keycombo) after working in the editor window, but this isn’t too bad. The restarted script would pick up right where the closed one was (with all settings intact).
                                          @Alan-Kilborn said,
                                          And in chat, he asked me to give it a test drive.
                                          From the user perspective, I was able to follow the instructions on @Ekopalypse’s GitHub page to get the WinDialog directory installed in my instance, and @Alan-Kilborn’s instructions to run his wrapper. So “yay” for sufficient “installation” instructions on both. :-)
                                          Indeed. Even after having read this paragraph, and knowing that it was modal, I still tried to change my selection in the editor without closing the dialog. So yes, having a modeless option for dialogs would definitely help with the user interface.
                                          Ah, I assume this was the use-case for you wanting to capture the ESC / X events <update>-- whoops, left that sentence hanging, without explaining that I meant that I thought you wanted it to be able to save settings, without having an OK button. I might recommend seeing if you can get on-changed events for the individual settings controls, and have them save their settings, whether or not OK (or, in your case, Count) is eventually pressed</update>
                                          (And sorry, Alan, I know you were encouraging me to comment on the LittleDialogWrapper aspects as well – presumably from a developer perspective – to see if I could put it through more paces. But until I switch over to PS3 whenever it’s out of alpha, I’m not likely to incorporate LittleDialogWrapper into any of my scripts, because my PS installation is going to stay at whichever can be easily found in Plugins Admin, so that when I’m trying to help users with PS solutions, they won’t have an extra step of installing the alpha version of the plugin manually, or so I don’t have to go switch to a different instance of Notepad++ compared to my normal workflow. So all I’ve got for now is what I said in April, and my brief user-perspective comments in this post.)
                                            My points about “modeless” and “easier saving of settings” were totally separate.
                                            I wasn’t really saying that the dialog should truly be “modeless”, because if it were, users would attempt to run other scripts after refocusing the editing window (leaving the dialog open), and PythonScript, presumably for good reasons, disallows running a second script while a first is running.
                                            So my thinking was the dialog script could end when focus is lost, to be restored when next invoked. (Ah, okay, I see the relationship of “saving the settings” – but truly, this was an earlier, separate point).
                                            Sure. Again, my earlier point was that this is “drudge work”. I have to have a “click” event on every control, even one that normally doesn’t need one, just for saving its state?? How about just a single function that gets called, whenever the dialog is about to close, by any means, that allows me to do “cleanup”, be it saving settings or something else?
                                            But until I switch over to PS3 …
                                            I decided to make the switch recently, although I still have to sort out some things that don’t work in scripts I had totally working under PS2.
                                            In general, I think it is time to move forward on this. PS3 may never come out of “alpha”, because what keeps it there (lack of old encoding support) doesn’t seem to get worked on.
                                            It seems reasonable that the PS developers make v. 3.x the one that Plugins Admin installs, but keep 2.x around for those that use scripting with dated encodings. Or heck, even make BOTH PS3 and PS2 installable via Plugins Admin.
