    Help with finding prefixes & selecting entire string
    3 Posts 3 Posters 389 Views
    • Miska VirtanenM
      Miska Virtanen
      Hello!
      I just wanted to ask, if there was a relatively simple way to find the prefix to a string, and automatically highlight the entire string with Find & Replace. What I’m trying to do is mass edit CSV files. The strings are separated by commas.
      Let’s say a file has data like this;
      bb_1234,aa_1233,cb_1244
      If I wanted to find all the strings starting with “bb_”, and highlight & replace the entire string, up until the next comma. So replacing the bb_ prefix data with something like ZZZ should make the data appear as;
      ZZZ,aa_1233,cb_1244
      Thank you in advance!
        Terry R @Miska Virtanen
        @Miska-Virtanen said in Help with finding prefixes & selecting entire string:
        That can be done simply with a regular expression (regex). Using the Replace function you would have
        Find What:\bbb_[^,]+
        Replace With:ZZZ
        Search mode must be set to regular expression.
        It didn’t sound as if it was only at the start of a line, hence my regex will look for that sequence in any “cell”. If this isn’t what you actually wanted you will need to elaborate.
        Pool StripP 1 Reply Last reply Reply Quote 5
        • Pool StripP
          Pool Strip @Terry R
          Terry-R said in Help with finding prefixes & selecting entire string:
          Replace With:ZZZ
          Thanks.
