    regex help with reverse line
    13 Posts 6 Posters 2.2k Views 2 Watching
    • namx3249N Offline
      namx3249
      hi everybody,
      i need to reverse line on my document with over 5000 lines. work fine Reverse line order (from Line operation) but i need to select manually each block so not easy for me!
      i have block like this one:
      (blank empty line)
      aaaaaaa
      bbbbbb
      ccccccc
      (blank empty line)
      eeeeeeeee
      wwwwww
      ppppppp
      (blank empty line)
      i need to reverse line 2 with line 4 like this one:
      (blank empty line)
      ccccccc
      bbbbbb
      aaaaaaa
      (blank empty line)
      ppppppp
      wwwwww
      eeeeeeeee
      (blank empty line)
      now my current regex is:
      find what: (?-s)^(^.*\R)(.+\R)((?:.+\R)*?)(.+\R)(?=^)
      replace: \1\4\3\2
      but this regex reverse line 2 with 3, not 2 with 4
      what wrong on my regex? thanks for your attention
        Alan Kilborn @namx3249
        @namx3249 said in regex help with reverse line:
        (blank empty line)
        aaaaaaa
        bbbbbb
        ccccccc
        (blank empty line)
        eeeeeeeee
        wwwwww
        ppppppp
        (blank empty line)
        I see no reason that this won’t work on your data:
        Find: ^\(blank empty line\)\R\K(.+\R)(.+\R)(.+\R)
        Replace: ${3}${2}${1}
        • namx3249N Offline
          namx3249
          thanks for your reply, but maybe my mistake, i expressed badly myself: with (blank empty line) i mean blank line like this one:
          aaaaaaa
          bbbbbb
          ccccccc
          eeeeeeeee
          wwwwww
          ppppppp
          sorry for that
          Mark OlsonM 1 Reply Last reply Reply Quote 1
          • Mark OlsonM Offline
            Mark Olson @namx3249
            @namx3249
            find/replace (.+\R)(.+\R)(.+)(\R)? with \3(?4\4:\r\n)\2\1 aught to work fine.
            Note that the much simpler find/replace (.+\R)(.+\R)(.+\R) with \3\2\1 will also work fine, but it will miss the edge case where the EOF comes after the third line in the group.
            • namx3249N Offline
              namx3249
              oh great. both regex work fine for my document.
              only i don’t understand from second simply regex:
              … it will miss the edge case where the EOF comes after the third line in the group
              what is EOF ? sorry for my ignorance …!
                @namx3249
                EOF = end of file
                • namx3249N Offline
                  namx3249
                  ok understand.
                  another small question: if i want put each block line to single line only, like this one:
                  aaaaaaa bbbbbb ccccccc
                  eeeeeeeee wwwwww ppppppp
                  which regex does this? works well with Line Operations - Join Lines but this requires selecting each individual block and this isn’t easy to do if the document has many blocks
                  • PeterJonesP Online
                    PeterJones @namx3249
                    @namx3249 ,
                    Assuming that you want to collapse any newline that isn’t preceded or followed by a newline into a space, I would say,
                    • FIND = (?<!\r\n)(?!\A)(\r\n)(?!\r\n)
                    • REPLACE = \x20
                    • SEARCH MODE = regular expression
                    The search says “replace any Windows newline not preceded by newline; not preceded by beginning of the file, and not followed by a newline” and the replacement is a single space character (I showed an escape, because it can be copy/pasted easily from the forum; really, you could just type the space character in your replacement field.)
                    before
                    aaaaaaa
                    bbbbbb
                    ccccccc
                    eeeeeeeee
                    wwwwww
                    ppppppp
                    after
                    • namx3249N Offline
                      namx3249
                      wow, awesome. thank you for this regex
                      I thought it more easy … understood that the block is selected with (.+\R)(.+\R)(.+\R) i thought it was easy to put right value in replace field
                      Luckily for me there is this wonderful forum!
                      Thank you all for your attention and greetings to everybody
                      • namx3249N namx3249 referenced this topic on
                        There is more than one way to do it.
                        • FIND = (.+)\R(.+)\R(.+)$
                        • REPLACE = $1 $2 $3
                        • un-checkmark . matches newline
                        would do it, too. My previous solution made no assumption about number of lines in each block. This variant assumes exactly three in a block.
                        • namx3249N Offline
                          namx3249
                          oh nice. thanks for this clarification !
                          i hope, step by step, to understand the amazing world of regex, very hard for me !
                          Regards
                          • sky 247S Offline
                            sky 247
                            The regular expression you provided is reversing the second and third lines because of the way it captures the text blocks. To reverse the second and fourth lines, you need to modify the regular expression to capture the second and fourth lines as separate groups. Here’s a modified version of the regular expression that should work:
                            Find what: (?-s)^(\h*\R|\R?\n)(.+)(\R)(.+)(\h*\R|\R?\n)
                            Replace with: \1\4\3\2\5
                            Explanation of the regular expression:
                            (?-s) - Disables dot-matches-all mode.
                            ^ - Matches the start of a line.
                            (\h*\R|\R?\n) - Matches a blank line. \h* matches zero or more horizontal whitespace characters, and \R|\R?\n matches either a line break sequence (CR, LF, CRLF, or Unicode line separator) or an optional CR followed by an LF.
                            (.+) - Matches the first non-blank line and captures it in group 2.
                            (\R) - Matches the line break sequence after the first non-blank line and captures it in group 3.
                            (.+) - Matches the second non-blank line and captures it in group 4.
                            (\h*\R|\R?\n) - Matches another blank line.
                            The replace pattern:
                            \1\4\3\2\5 - Replaces the match with the captured groups in the desired order. The first and fifth groups (the blank lines) remain in their original positions, and the second and fourth groups (the non-blank lines) are swapped by reversing their order. click here to see live example
                            I hope this helps! Let me know if you have any further questions.
                            • guy038G Offline
                              Hello, @namx3249, @alan-kilborn, @mark-olson, @peterjones, @sky-247 and All,
                              I found out a general method to reverse the lines of sections, separated with a pure empty line :
                              • Whatever the number of lines of each section
                              • Whatever the number of sections
                              Let’s go :
                              We start with the following INPUT text :
                              01
                              02
                              03
                              04
                              aaaaa
                              bbbbb
                              ccccc
                              ddddd
                              eeeee
                              fffff
                              ggggg
                              hhhhh
                              iiiii
                              05
                              06
                              07
                              08
                              09
                              10
                              11
                              01
                              02
                              03
                              FIRST Line
                              Second line
                              Third line
                              Fourth line
                              Fifth line
                              LAST line
                              Note the empty line at the very beginning of the data ! ( Important )
                              With this first regex S/R, we replace any EOL chars, not followed with other EOL chars, with a colon character
                              • SEARCH (?x) \R (?! ^\R )
                              • REPLACE :
                              We get this temporary text :
                              :01:02:03:04
                              :aaaaa:bbbbb:ccccc:ddddd:eeeee:fffff:ggggg:hhhhh:iiiii
                              :05:06
                              :07:08:09:10:11
                              :01:02:03
                              :FIRST Line:Second line:Third line:Fourth line:Fifth line:LAST line
                              As you can see :
                              • Any section is rewritten in a single line
                              • Any previous line is simply preceded with a colon character
                              • Any line must end with text without a colon character
                              Now, with this second regex S/R, we separate each line in two parts :
                              • A first part between the first colon of the line and right before the last colon
                              • A second part from after the last colon till the end of current line
                              • In the replacement phase, we rewrite these two parts, in reverse order, with a leading slash
                              SEARCH (?x) ( : .+ ) : ( .+ )
                              REPLACE /\2\1
                              Click of the Replace All button as many times as the maximum number of lines in sections
                              Regarding our example, you should click nine times on the Replace All button !
                              You may also hit the Alt + A shortcut, repeatedly, till the message Replace All: 0 occurrence were replaced... occurs
                              And we get this temporary text below :
                              /04/03/02:01
                              /iiiii/hhhhh/ggggg/fffff/eeeee/ddddd/ccccc/bbbbb:aaaaa
                              /06:05
                              /11/10/09/08:07
                              /03/02:01
                              /LAST line/Fifth line/Fourth line/Third line/Second line:FIRST Line
                              Finally, let’s come back to the normal displaying of your data, with this third regex S/R which simply replaces the colon and slash chracters with a line-break
                              SEARCH [:/]
                              REPLACE \r\n
                              Anc here is your expected OUTPUT text :
                              04
                              03
                              02
                              01
                              iiiii
                              hhhhh
                              ggggg
                              fffff
                              eeeee
                              ddddd
                              ccccc
                              bbbbb
                              aaaaa
                              06
                              05
                              11
                              10
                              09
                              08
                              07
                              03
                              02
                              01
                              LAST line
                              Fifth line
                              Fourth line
                              Third line
                              Second line
                              FIRST Line
                              Notes :
                              • The trivial cases, of a single data section only or sections of one line only, are correctly handled, too !
                              • Any additional line-breaks, between sections, are preserved in your OUTPUT text
                              • Of course, you can use any char, instead of the colon and the slash characters :
                                • Provided that they cannot be found in your present INPUT data
                                • Provided that you modify the regexes, accordingly
                              • As said above, the second regex S/R needs N successive searches/replacements, where N is the number of lines of the longest section, in your data
                              • BTW, if you redo all the same process, you get the original order of each section !!
