    copy xml blocks with contains string
    4 Posts 3 Posters 976 Views
    • zemaria523Z
      zemaria523
      Hi, I have an xml that contains millions of lines like those xml blocks:
      <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
      <plist version="1.0">
      <dict>
      	<key>relativePath</key>
      	<string>Library/Preferences/com.apple.Safari.SafeBrowsing.plist</string>
      	<key>birth</key>
      	<string>6955023</string>
      	<key>groupID</key>
      	<string>501</string>
      	<key>mode</key>
      	<string>33152</string>
      	<key>modified</key>
      	<string>4444</string>
      	<key>statusChanged</key>
      	<string>695502523</string>
      	<key>userID</key>
      	<key>size</key>
      	<string>103</string>
      </dict>
      </plist>","contents":{"signature":"BDuaupIWv889qLBr41lViCemOSlz","owner":"55555555","size":128,"reference_signature":"AYh7zng="UTF-8"?>
      <dict>
      	<string>Library/Preferences/com.apple.SetupAssistant.plist</string>
      	<key>birth</key>
      	<string>6945</string>
      	<key>groupID</key>
      	<key>mode</key>
      	<key>modified</key>
      	<string>695045</string>
      	<string>44444</string>
      	<key>userID</key>
      	<key>size</key>
      	<string>161</string>
      </dict>
      </plist>","contents":{"signature":"fffdssffsfs","owner":"5555555","size":256," encoding="UTF-8"?>
      I want to copy all whole block <!DOCTYPE … </plist> that contains inside the word SetupAssistant, is there a way to do that?
      • Mark OlsonM
        Mark Olson @zemaria523
        @zemaria523
        Kinda ugly, but try going to the Mark tab of the find/replace window, finding (?s-i:<!DOCTYPE\s+plist(?:(?!</plist>).)*?SetupAssistant(?:(?!</plist>).)*?</plist>), hitting Mark All, and then Copy Marked Text.
        From the above example, the text copied will be
        <dict>
        	<key>birth</key>
        	<key>groupID</key>
        	<key>mode</key>
        	<key>modified</key>
        	<key>userID</key>
        	<key>size</key>
        </dict>
        </plist>
        You will get some lines with ---- in between each marked thing. I suppose you could find/replace ^----$ with nothing to get rid of those.
        Explanation:
        1. <!DOCTYPE\s+plist finds the doctype declaration.
        2. (?:(?!</plist>).)*?SetupAssistant matches the text SetupAssistant up to and including SetupAssistant before the next </plist> close tag.
        3. (?:(?!</plist>).)*?</plist> finds all text up to and including the close tag.
        Alan KilbornA zemaria523Z 2 Replies Last reply Reply Quote 4
          Alan Kilborn @Mark Olson
          @Mark-Olson said in copy xml blocks with contains string:
          This happens to delimit the matches when each match is multiline.
          For the situation here, it is pretty clear where the matches separate, but it is not always so clear, so the ---- is put in.
          At least, that’s my interpretation as to the “why” it is there.
          I don’t think I’ve ever seen this explained before.
          As you say, easy enough to remove with a regex replacement operation.
          • zemaria523Z
            zemaria523 @Mark Olson
            @Mark-Olson Thank you very much. it solved my problem!
