    Help with Regex
    4 Posts 3 Posters 288 Views
    • PangolinP
      Pangolin
      My knowledge with Regex is limited to add a text at the beginning of a line or the end of it.
      So I tried with ChatGpt to get a code to do what I want but without any success. I hope you will understand my explanations on what I’m looking to do.
      First EOL conversion is on LF.
      I have over text with over 30 000 lines.
      With two kinds of listing
      First :
      Movie Title
      Director
      Actor 1
      Actor 2
      Actor 3
      and so on
      Second
      Movie Title
      Actor 1
      Actor 2
      Actor 3
      and so on
      What I want to do is:
      When “Director” is present remove the first line “Movie Title” and all the lines that begins with “actor”.
      If “Director” is not present. Keep the paragraph.
      Thanks for your help
      • Mark OlsonM
        Mark Olson @Pangolin
        @Pangolin
        Looks like this should work:
        Replace (Movie Title:.+(?:\R|\Z))(Director:.+(?:\R|\Z))?((?:Actor.*?:.+(?:\R|\Z))*) with ?2\2:\1\3
        Make sure . matches newline is turned off.
        Explanation:
        1. (?:\R|\Z) matches any newline (including, CR, CRLF, LF) or the end of the file.
        2. There are three capture groups, one for the movie title, one for director, and one for zero or more actors.
        3. In the replacement, the syntax ?2\2|\1\3 means we should replace with the second capture group (director) only if director was matched. Otherwise, we should replace with the other two capture groups (movie title and any number of actors).
        I was able to convert
        Movie Title: Baz to the Bone
        Director: Bazeven Bazlberg
        Actor 1: baz bazsson
        Actor 2: foo foosson
        Actor 3: bar barsson
        Movie Title: Foo Manchu
        Actor 1: foo foostein
        Actor 2: bar barstein
        Actor 3: baz bazstein
        Movie Title: Conan the BarBarian
        Director: Baron Dracula
        Actor 1: baz bazmeister
        Actor 2: foo foomeister
        Actor 3: bar barmeister
        to
        Note that a ? after the second capture group is optional for this use case. The find/replace works fine either way, and performance is slightly faster if you don’t include the ?.
        However, not including the ? comes at the cost of failing to match anything where the director is not listed, which could be problematic for related use cases.
          Hello, @pangolin, @mark-olson and All,
          Here is an other formulation ! Just one constraint : add one / two line-break(s) at the very end of your file !
          SEARCH (?-si)^Movie Title.*\RDirector.*\R(?:Actor.*\R)*\R+
          REPLACE Leave EMPTY
          Notes :
          • The strings Movie Title, Director and Actor must have this exact case
          • The strings Movie Title, Director and Actor can be followed or not with a name
          • The string Actor may not be present in a paragraph block
          • The end of each block to delete may contain several consecutive line-breaks
          Test it, for instance, against this text :
          Movie Title
          Director
          Actor
          Actor
          Actor
          Movie Title
          Actor 1
          Actor 2
          Actor 3
          Movie Title
          Director
          Movie Title
          Director
          Test 1
          Test 2
          Test 3
          Movie Title
          Director ...
          Actor ...
          Actor ...
          Actor ...
          Best regards,
          PangolinP 1 Reply Last reply Reply Quote 0
          • PangolinP
            Pangolin @guy038
            Thank you very much Mark and Guy for taking the time to answer my request. It is really appreciated!
            Have a nice evening
