    Document Map Highlighter shown on weird location for 4K Monitor
    4 Posts 2 Posters 568 Views
    • AmitA
      Amit
      I recently got a 4K monitor and have it set to 200% DPI. (See below)
      The Document Map (aka Mini map) highlighter shows up in the middle of the Notepad++, instead of placed in the document map itself.
      Can anyone help, why is it doing that? Is this a bug?
        Alan Kilborn @Amit
        @Amit
        Notepad++ just doesn’t have great support for these types of monitors.
        AmitA 1 Reply Last reply Reply Quote 0
        • AmitA
          Amit @Alan Kilborn
          @Alan-Kilborn Are there a post on this forum for Recommendations for those who are using Notepad++ on 4K monitors? It would be a nice edition to have some notes/workarounds to play it nice with 4K resolution. Thanks.
            Alan Kilborn @Amit
            @Amit said in Document Map Highlighter shown on weird location for 4K Monitor:
            There’s a search capability for this forum.
            You also might check out actual ISSUES filed against the software.
            Good luck.
