    SurroundSelection sometimes hijacks shortcut Ctrl+Shift+2
    5 Posts 3 Posters 439 Views
    • Neil SchipperN
      Neil Schipper
      I’m pasting in the issue I submitted over at dail’s SurroundSelection project.
      I (and maybe also dail) would like to know if other people are seeing the same behavior.
      When SurrSel is enabled, and text is selected, shortcut Ctrl+Shift+2 results in a SurrSel-like action where the text is surrounded by a pair of NUL:
      … rather than the default action of jumping to the previous instance of text with “Style 2”.
      Problem goes away when SurrSel is disabled.
      If no text is selected, the shortcut does the expecting jumping.
      Notepad++ v8.4.9   (64-bit)
      Build time : Jan 27 2023 - 03:11:16
      Path : C:\Users\Guest!\Downloads\npp.8.4.9.portable.x64\notepad++.exe
      Command Line :
      Local Conf mode : ON
      OS Version : 21H2
      OS Build : 19044.2604
      Plugins :
          mimeTools (2.9)
          NavigateTo (2.4.1)
          NppConverter (4.5)
          NppExec (0.8.2)
          PythonScript (2)
          SurroundSelection (1.4.1)
          VisualStudioLineCopy (1.0.0.2)
          _CustomizeToolbar (5.3)
        Michael Vincent @Neil Schipper
        @Neil-Schipper said in SurroundSelection sometimes hijacks shortcut Ctrl+Shift+2:
        Oh, yeah - me too! I never use that key combo though so would probably never have noticed it.
        • rdipardoR
          rdipardo
          This appears to fix it:
          diff --git a/src/Main.cpp b/src/Main.cpp
          index 2b159ef..030e2db 100644
          --- a/src/Main.cpp
          +++ b/src/Main.cpp
          @@ -77,8 +77,11 @@ static void prepareKeyboardChars() {
           	kbProcessChars.clear();
           	// Default characters
          -	for (UCHAR c : "\"'(){}[]<>`")
          +	const char *defaultChars = "\"'(){}[]<>`";
          +	for (unsigned i = 0; defaultChars[i]; i++) {
          +		UCHAR c = (UCHAR)defaultChars[i];
           		processChars[c] = TRUE;
           	// Add user defined
           	for (SIZE_T i = 0, j = _tcslen(addChars); i < j; i++)
          Explanation and patched binaries here.
          Neil SchipperN 1 Reply Last reply Reply Quote 2
          • Neil SchipperN
            Neil Schipper @rdipardo
            @rdipardo Thanks for the prompt attention. As it turns out I can’t test the fix for a day or a few (due to: house sitting, guest account, Norton prevents extracting dll from downloaded zip).
            • rdipardoR
              rdipardo @Neil Schipper
              If anyone visiting this thread is in similar circumstances, AppVeyor artifacts will be online until about MAR-28-2023:
              • SurroundSelection (patched) x64
              • SurroundSelection (patched) Win32
