    Replacing/Translating multi string values to other international language
    7 Posts 2 Posters 2.2k Views 1 Watching
    • Faseeh ShahF Offline
      Faseeh Shah
      Hi guys, a newbie here
      I have a strings.xml file.
      Is there a way to replace or translate multi string values to other international language
      <string name=“jewellery”>Jewellery</string>
      <string name=“photo_editor”>Photo Editor</string>
      <string name=“gallery”>Gallery</string>
      so basicaly I want to translate Jewellery, Photo Editor and Gallery from english to any other language of choice.
      Thanks in advance
        Alan Kilborn @Faseeh Shah
        @Faseeh-Shah
        Do you have a list of the words/phrases to translate, and then the various translations, a possible short example might be:
        Jewellery,Joyas,Bijoux
        Gallery,Galería,Galerie
        Faseeh ShahF 1 Reply Last reply Reply Quote 0
          Faseeh Shah @Alan Kilborn
          Yes I have or I can mark copy the string values and use google translate.
            @Faseeh-Shah
            It’s hard to anticipate the larger framework of what you’re doing, in order to know what advice to provide, but with what you’ve given, if I were doing it, I’d think in terms of a “mail merge” (also a shameless plug for my recent script for such a thing).
            Let’s consider the technique shown in THIS THREAD for your situation.
            I’d prepare a “template” file/tab:
            ----<LANG>----
            <string name="jewellery"><JEWELLERY></string>
            <string name="photo_editor"><PHOTO EDITOR></string>
            <string name="gallery"><GALLERY></string>
            so basicaly I want to translate <JEWELLERY>, <PHOTO EDITOR> and <GALLERY> from english to any other language of choice.
            Thanks in advance
            and a “data table” file/tab:
            <LANG>|<JEWELLERY>|<PHOTO EDITOR>|<GALLERY>
            English|Jewellery|Photo Editor|Gallery
            Spanish|Joyas|Editora de fotos|Galería
            French|Bijoux|éditeur de photos|Galerie
            Then I’d run the “mail merge” to obtain:
            ----English----
            <string name="jewellery">Jewellery</string>
            <string name="photo_editor">Photo Editor</string>
            <string name="gallery">Gallery</string>
            Thanks in advance
            ----Spanish----
            <string name="jewellery">Joyas</string>
            <string name="photo_editor">Editora de fotos</string>
            <string name="gallery">Galería</string>
            so basicaly I want to translate Joyas, Editora de fotos and Galería from english to any other language of choice.
            Thanks in advance
            ----French----
            <string name="jewellery">Bijoux</string>
            <string name="photo_editor">éditeur de photos</string>
            <string name="gallery">Galerie</string>
            so basicaly I want to translate Bijoux, éditeur de photos and Galerie from english to any other language of choice.
            Thanks in advance
            Then, if I were interested in the representation of the original data in Spanish, for example, I’d find that section in the output, and copy it to a new file/tab or wherever I needed it to be.
            If you wanted a semi-automated way of copying the data from the results, you could make a macro of a Mark All operation for regex ^----Spanish----\R\K(?s).*?(?=^----|\z), adding a Copy Marked Text to the macro after the mark. Then copying the data becomes as simple as running a macro (well, one macro per language).
            Faseeh ShahF 2 Replies Last reply Reply Quote 2
              Thank you, will check the plug for merging and let you know how it went. Yes, theoretically what you advised should solve my prob.
                Luckily I found solution, a script.
                Script could be found here in action:
                https://asrt.gluege.boerde.de/
                Source:
                https://github.com/Ra-Na/GTranslate-strings-xml
                Thanks for helping tho.
                  @Faseeh-Shah said in Replacing/Translating multi string values to other international language:
                  If that’s what you were looking for, you shouldn’t have asked your original question in a Notepad++ forum, as it is OFF-TOPIC.
                  Here we only deal with what Notepad++ can do for you, and what you can do with it.
                  In other words, your question must be related to Notepad++ in some way. Your question was NOT.
