    Install Problem
    2 Posts 2 Posters 331 Views
    • Dean Davis62D
      Dean Davis62
      I am trying to install Notepad++ I get the language window , I get the Welcome window but the next window says License agreement at the top and says review license agreement but no place to accept it then it closes. I have tried both of the most recent versions with the same result. 8.4.7 and 8.4.8. Any ideas out there???
        Terry R @Dean Davis62
        @Dean-Davis62 said in Install Problem:
        I just tried the 8.4.8 installer (32bit) and after setting English (default since the laptop is set to english) I also get to the licence window which has “I agree” at the bottom to proceed.
        So firstly, which language are using using to install with (maybe an issue with that language so I could attempt to use that setting). Also can you do a screen print of the licence window? You can copy it (use snipping tool if wish to minimize what is shown) and the paste directly into a post here. Also which version of Windows are you installing onto?
