    functionlist problem
    22 Posts 4 Posters 6.2k Views
      PeterJones @swegmike
      @swegmike said in functionlist problem:
      think the ability to modify a post til it shows correctly needs to be fixed
      NodeBB are the authors of the forum software. The Notepad++ just uses an instance (that NodeBB team also kindly donates the server space for our Community). Neither I nor Don have any ability to change the base code for NodeBB, nor do we have any particular sway with NodeBB in getting code changed.
        Is there a way to have the functionlist show multiple lines
        Nope
        Or where the regexp can manipulate the multiline into one for the functionlist to display it completely
        I believe the manual explicitly stated that the functionalist regex cannot change the text; it is a match-only expression
