    Backup plugins and their settings
    5 Posts 3 Posters 527 Views
    • Destroy666xD
      Destroy666x
      Hi,
      what would be the easiest way to achieve this? I noticed there are plugin files in Program FIles and some configs in Roaming, not sure about other locations. Is there any plugin to get all?
        PeterJones @Destroy666x
        @Destroy666x ,
        The plugin and any libraries and accouterments go in the install directory. The plugin settings (and sometimes other per-user files for the plugin) go in %AppData% hierarchy (or “Roaming” as you call it)
        Destroy666xD 1 Reply Last reply Reply Quote 1
        • Destroy666xD
          Destroy666x @PeterJones
          @PeterJones yea, that’s pretty much what I wrote in initial post (except some plugins have settings in install dir), so no other way of backing them up?
          Also, another question I forgot to type, is copying the files sufficient? Or does Npp keep some info about installed plugins in some db, registry or wherever?
            Alan Kilborn @Destroy666x
            @Destroy666x said in Backup plugins and their settings:
            Just copying the files is a fine method.
            No.
              I was confirming that your description was close enough, and thus trying to imply that thus all you had to do to back up a plugin was back up those two directories. I am sorry that my implication was not clear.
