    Problem with long file names
    3 Posts 2 Posters 348 Views
    • Henry GH
      Henry G
      I have changed the Registry so that I can edit batch files with NP++ via
      “C:\Program Files\Utils\Notepad++\notepad++.exe” %1
      but it only works with 8.3 “short file names” even though I use Windows 11x64.
      Any easy solution for this that does not involve renaming my batch file please? Although I can use “send to” instead.
      datatraveller1D 1 Reply Last reply Reply Quote 0
      • datatraveller1D
        datatraveller1 @Henry G
        @Henry-G said in Problem with long file names:
        Does
        "C:\Program Files\Utils\Notepad++\notepad++.exe" "%1"
        help to solve the issue?
        • Henry GH
          Henry G
          Excellent! Thank you :-}
          And I’m sure it will come in use elsewhere.
