autoCompletion Issue
@Lycan-Thrope
Hey, hey :¬) …
It makes me feel like I’m reinventing the wheel, and I clarify that I’m not creating a lexer, just creating the auto-complete list, if you have any, it could save me time, or serve me as a guide. I tell you that I got the list to work in modeignoreCase="yes"- I already filled thedescr="abcd...", Npp’s RegEx engine and an index of Commands and Functions saved me days of hard work. I just need to fill in the parameters and return values. (handwork). The lexer thing, it’s still too big for me :¬( -
@José-Luis-Montero-Castellanos ,
I meant, that you’re making a UDL feature like I was, not a Lexer. Sorry if that wasn’t clear. Yes a Lexer was going to be too much for me, too…but this is almost as big. :) -
@Lycan- I understand.
If you are interested, now or when I have it completely ready, I will send it to you. For now I’m trying the suggestions…By the way, I’m missing the syntax coloring list (userDefineLanguage). One I downloaded (hmg.xml) doesn’t meet my expectations, I want one for dark themes.
Well, I took a look at the Harbor language part and checked out the documentation about the commands and such, and sorry to say, the two aren’t really similar enough for you to do cut and paste since a lot of it is based on the older Xbase procedural and Clipper extensions styles and not true OOP, which seems closer in coding to a C++ style of object creation and such…and honestly, most of the links for Harbour were dead end 404 pages that I tried to follow from Wikipidia and search engines.
What I can give you is a view of a few of the Xbase commands and how it should look, but I’m afraid the hard work is going to be yours to collect all the languages commands and put in to the autoCompletion file in the order you need.
<KeyWord name="DELETE"/> <KeyWord name="DELETED" func="yes"> <Overload retVal="{lVal}" descr="Xbase - Indicates if the current record is marked as deleted."> <Param name="[<alias>]"/> </Overload> </KeyWord> <KeyWord name="DESCENDING" func="yes"> <Overload retVal="{lVal}" descr="Xbase - Indicates if a specified index is in descending order."> <Param name="[<.mdx filename expC>]"/> <Param name="[<index position expN>"/> <Param name="[<alias>]]"/> </Overload> </KeyWord>Notice the keyword only gets that one line entry, but functions /methods get the multiple line entry, and if any of the commands have multiple application you can add multiple Overload sections to expand it so that each will show up in the drop box when you type the first parenthesis that triggers the description/tips for the chosen word when it is meant to be used as a function/method rather than a command word. Note that it says
1 of 4because there are 4 uses/variations of the command to choose from if you use the tip call to follow the hints of parameters to enter as shown in the below screenshot.
Note also, the previous code clip where the word is DELETE in caps, and there is no multiple Overload sections…that’s because when it’s used as anything other than a command, it won’t be in capitals, so it may have a lower case equivalent, but the lower case function/method use won’t have an uppercase equivalent.
<KeyWord name="delete"/> <KeyWord name="delete" func="yes"> <Overload retVal="{null}" descr="Method - Deletes the current row. Property of: Rowset, ArrayRowset Usage: <oRef> .delete() - <oRef> = The rowset whose current row you want to delete."> <Param name=""/> </Overload> <Overload retVal="{null}" descr="Method - Deletes an element from a one-dimensional array, or deletes a row or column of elements from a two-dimensional array. Property of: Array Usage: <oRef> .delete(<position expN> [, <row/column expN> ]) - <oRef> = A reference to the one- or two-dimensional array from which you want to delete data. <position expN> - When the array is a one-dimensional array, <position expN> specifies the number of the element to delete. When the array is a two-dimensional array, <position expN> specifies the number of the row or column whose elements you want to delete. [<row/column expN> ] - Either 1 or 2. If you omit this argument or specify 1, a row is deleted from a two-dimensional array. If you specify 2, a column is deleted."> <Param name="<position expN> "/> <Param name="<row/column expN> "/> </Overload> <Overload retVal="{null}" descr="Method - Removes a file from a disk, optionally sending it to the Recycle Bin. Property of: File Usage: <oRef> .delete(<filename expC> [, <recycle expL> ]) - <oRef> = A reference to a File object. <filename expC> - Identifies the file to remove. [<recycle expL> ] - Whether to send the file to the Recycle Bin instead of deleting it. If omitted, the file is deleted."> <Param name="<filename expC> "/> <Param name="[<recycle expL> ]"/> </Overload> <Overload retVal="{null}" descr="Method - Deletes the rows in the destination that are listed in the source. Property of: UpdateSet Usage: <oRef> .delete() - <oRef> = The UpdateSet object that describes the delete."> <Param name=""/> </Overload> </KeyWord>This might help, but the bulk work of documenting and turning your language documentation into an autoCompletion and code tip file is on you and believe me, I know how much work it is…but our language implementations are so far apart in documenting format that you won’t be able to use mine. Harbour is what is referred to as object based but not fully object oriented as dBASE Plus is.
I hope this helps you understand the size of a job you’ve chosen to do. It’s one of the reasons that creating a UDL with the additional features wasn’t done prior to my doing it. It’s not a job for the faint of heart. :)
Hi: @Lycan-Thrope
Anyway, I’m still learning details from your observations, and I’d like to know what programming environment you make your languagx.xml file for.
Regarding the documentation to copy and paste, I’ll give you the link so you can browse it (if you’re curious).
https://www.hmgforum.com/hmgdoc/data/index.htm
In one day with the help of Npp’s RegEx I loaded aprox. 780 descriptions of commands and functions.
Application
Do() Calls a procedure or a function
hb_PValue() Retrieves the value of an argument.
PCount() Retrieves the number of arguments passed to a function.
ProcFile() This function always returns an empty string.
ProcLine() Gets the line number of the current function on the stack.
ProcName() Gets the name of the current function on the stackArray
AAdd() Dynamically add an element to an array
AClone() Duplicate a multidimensional array
ACopy() Copy elements from one array to another
ADel() Delete an element from an array.
AEval() Evaluates the subscript element of an array
AFill() Fill an array with a specified value
AIns() Insert a NIL value at an array subscript position.
Array() Create an uninitialized array of …The list contains the name of the function or command with its description easily convertible to autocomplete format with just one run of Find and Replace All.
From your previous comment I was able to assimilate an example of how to arrange the parameters, for which I only used one line. Thanks again! and hopefully my heart doesn’t fail me :¬) .
Thanks for that working link. At least from it, I was able to glean at least the following:The language uses older object-based structures that older dBASE did. It uses a C like include system for including files that have supporting code plus it uses a C like Main Function approach similar to C style, and since it’s based on Clipper, which was a C like compiler for Xbase languages that makes sense.
I guess you could use my file, but you’d have to do a lot of editing removing things, which it sounds like you have a better handle on it and easier access to extrapolate and search the availble text than I did. I had to copy everything from the documentation and help files into the autoCompletion file…there was no text file to draw on…I had to create it. :) Then I was able to start sorting and using Notepad++ to form it, so you’re already ahead of the game as far as work to do is concerned…and that being said, the examples I gave you should give you the guidance you need to apply it to your language’s documented functions etc.
Now you just need to do what ever sorting you need and apply whatever search and replace you need, like I did. As someone suggested, I went through the list, and every word that was a command only, I marked somehow with a phrase that I could then use to apply a skeleton search and relplace for the front of the command word (like those I showed you), and then the same for the back side (opening closing xml tags for instance).
The functions took longer because I had to manually enter the information after using a skeleton frame for each part of structure, and I had a cut and paste text file of those structures so I could for instance, paste multiple “Overload…/Overload” skeletons and then hand fill each. It helped make it faster, but it was still tedious.
Incidentally, I was going to make an older dBASE version file also, but hadn’t gotten on it yet, that would probably have been more similar to what you’re doing now…but alas, I never got to it.
@José-Luis-Montero-Castellanos said in autoCompletion Issue:
I’m not quite sure what you’re asking here? I use the dBASEPlus UDL I developed named dbaseplus.xml, but it’s not in the library yet, as need I to finish it up. If you’re asking what environment I use it for, I use it for an outside of the IDE editor for dBASE Plus, which is made by dBASE, LLC that you can read more about it here:
dBASE PLusI’m using dBASE Plus right now to write an installer for it, because the files used in Notepad++ to implement these features have multiple files with the same name and in the same case, so it’s sometimes hard for folks to install it. I’m in testing of it right now, and have come across a couple of people whose NPP installs don’t have the standard directory structure that it should for me to install into. In particular, as I understand, they have no AppData\Notepad++\functionList\ directory to hold the dbaseplus.xml functionList file, and the overrideMap.xml file that they need to link these things for the UDL language to the functionList and autoCompletion features and I’m trying to work it out with them now to find out why. Once it’s done and working I was going to release it for use in the library. Have been delayed somewhat when I started a job in July, and now I’m back at it while I look for another one since I left it at the end of September :)
I’ll keep an eye out on your progress on here and if I can help with examples or what not, I’ll be glad to jump in. Good luck.
Hi,
Your example doesn’t work for me. I write “cam” and nothing happens, no suggestions. It is rather not correct. “all” and “don” work fine.Notepad++ v8.4.7 (64-bit)
Build time : Nov 1 2022 - 23:31:11
Path : C:\Tools\Notepad++\notepad++.exe
Command Line : d:\Temp\test.au3
Local Conf mode : ON
OS Name : Windows 11 (64-bit)
OS Version : 21H2
OS Build : 22000.1335
Current ANSI codepage : 1250
Plugins : none -
@Grzegorz-Śliwka said in autoCompletion Issue:
Whereas it did work for me. Without giving us more to go on, I cannot even begin to guess what you’ve actually done, and whether you’ve really set things up right according the instructions above. Sorry.
